Sponsored by: Real Truck
TPMS sensor compatibility question 2015 F250
Old Feb 14, 2022 | 01:11 PM
snaponprofile's Avatar
snaponprofile
Hello all,
I recently did a wheel swap on my 2015 F250 and put 2021 tremor wheels on. I left the original TPM sensors in the 2021 wheels thinking they are Ford and thus compatible, but now I am not so sure. I bought a
$15 relearning tool from Amazon $15 relearning tool from Amazon
and put the truck into relearn mode and the wheels don't seem to be responding. The TPM system was working prior to this.
Did I buy the wrong relearning tool? Should I try the relearn method by letting the air out of tires in relearn mode?
I was just wondering if anyone knows if the new sensors are not compatible with my truck? If so, is there a simple way to disable the TPMS system?
Best,
Snapon
Ps: I also posted this in the suspension section, sorry for duplicate thread.
Old Feb 14, 2022 | 01:49 PM
Just Strokin's Avatar
Just Strokin
suppose to work with either the 315mhz or the 433mhz tpms sensors.
Do you know if the tpms tire sensors are being read by the truck?
Old Feb 14, 2022 | 03:25 PM
snaponprofile
I'm not sure how to know if the sensors are being read by the truck? When I place the truck in learning mode, I hold the tool to the base of the valve stem and press the button once while holding for 10-15 seconds. When I do this, nothing happens. I tried multiple wheels.
Old Feb 14, 2022 | 03:35 PM
92sho16's Avatar
92sho16
Sensors from 17+ do not work with 11-16 trucks.
Old Feb 14, 2022 | 03:46 PM
chukeeee's Avatar
chukeeee
Nope, I put a set of Tremor take-off wheels and tires on my 2016. I used forscan to disable the tpms, no problems.
Old Feb 14, 2022 | 04:20 PM
snaponprofile
Hmm, okay. I may look to disable the TPM system as well, seems like this could get expensive fast. I don't have a windows laptops so I have yet to set up and use Forscan.
Old Feb 14, 2022 | 05:52 PM
Just Strokin
You can get a set of sensor for the wheels/tires off eBay around $50.
Old Feb 14, 2022 | 09:59 PM
Mastertinner's Avatar
Mastertinner
Sometime after 2017 the tpms sensors are no longer compatible with the previous generation trucks. I have 2017 wheels and tpms sensors on my '16 and they work just fine.
Old Apr 3, 2024 | 10:07 PM
GASPIG88's Avatar
GASPIG88
Originally Posted by snaponprofile
Hello all,
I recently did a wheel swap on my 2015 F250 and put 2021 tremor wheels on. I left the original TPM sensors in the 2021 wheels thinking they are Ford and thus compatible, but now I am not so sure. I bought a $15 relearning tool from Amazon and put the truck into relearn mode and the wheels don't seem to be responding. The TPM system was working prior to this.
Best,
Snapon
Almost the same setup. Different Tremor wheel.
2024 Tremor Takeoffs on a 2012 F250 FX4
4 inch readylift rear blocks (only 2.375 taller than stock). 2.5inch skyjacker front spacers (under coil steel spacers). Skyjacker drop pitman arm, Readylift track bar bracket, Shocks from fox.
I love it! But my next set of shoes will be 37s.
snaponprofile
Feb 14, 2022 12:45 PM
Odyknuck
Jul 7, 2021 09:52 AM
matt0588
Nov 4, 2015 05:44 AM
Firewiz
Oct 8, 2013 08:12 AM
jda1961
2009 - 2014 F150
May 26, 2009 11:53 PM
