Procomp lift question
Old Feb 20, 2022 | 04:23 PM
Antonm's Avatar
Antonm
Typically the rear shims get installed such that they rotate the pinion angle down (closer to the ground) on a two joint rear shaft. Reason for this it to keep driveshafts vibrations to a minimum. See pic below.
Old Feb 20, 2022 | 05:25 PM
yzf450motoxrider's Avatar
yzf450motoxrider
@Antonm Interesting, That doesn't make sense the factory configuration had the pinon parallel with the driveshaft with the fat side of the factory blocks to the rear of the truck. In the diagram above if the pinion is rolled up it would reduce the angle at the diff to 0 and reduce the angle at the transfer case. Also is that diagram for the front axle?
Old Feb 20, 2022 | 05:54 PM
Antonm's Avatar
Antonm
The diagram works for either axle.
When you move the rear end down with lift springs, the angle of the rear output changes (you moved the axle farther down, but the transfer case output didn't move, the two are connected via a straight line driveshaft ,so the angle has to change).
Vibrations tend to be at a minimum when the angles of the two driveshaft u-joints are equal. So since the angle at the transfer case got steeper, the one at the rear end needs to get steeper as well to match. To accomplish that you roll the pinion down toward the ground.
Old Feb 20, 2022 | 06:38 PM
yzf450motoxrider
Got the logic, thanks.
Old Feb 20, 2022 | 06:49 PM
Dweber85rc's Avatar
Dweber85rc
Its also worth noting that 1-2 degrees on a driveline is hard to discern just by looking at it at least for a majority of the shade tree mechanics on the board here.
Old Feb 20, 2022 | 08:43 PM
yzf450motoxrider
Here is we’re I’m at measured from hub to wheel well is 29 inches much higher than I was hoping. This may be because the front end is on jack stands about 3 ft behind where the front axle would be so the engine weight is cantilevered out in front reducing the weight on the rear axle. Really hope it drops about an inch. Also in the process of rebuilding a d60 junkyard axle. Going to torque all the suspension components once the front axle is back in.
Old Feb 20, 2022 | 08:53 PM
Antonm's Avatar
Antonm
Looks like you’re gonna have a fun time getting it out of the garage eventually.
The roof of the truck is a good bit higher than the garage door.
Old Feb 20, 2022 | 08:57 PM
Dweber85rc's Avatar
Dweber85rc
You might want to double check that the shackle bolts are in the correct position on the rear springs. If put in the wrong way they will catch on the frame and not allow the spring to compress the way it should.
Old Feb 20, 2022 | 08:59 PM
yzf450motoxrider
Currently yes its about an inch higher, if it sat at 27" it would fit. If it doesn't settle Ill just air down the tires.
Old Feb 20, 2022 | 09:00 PM
yzf450motoxrider
Not catching the frame, checked and matched the stock set up.
Old May 8, 2022 | 06:28 PM
yzf450motoxrider
Just about done. Still need to get an alignment and new tires put on. Ended up going with Yokohama geolander 285/75r16 on a set of like new stock rims
Fully rebuilt and regeared Dana 60
All for corners at 27 inches hub center to fender
Old May 10, 2022 | 07:26 AM
yzf450motoxrider
What are the thoughts on the sway bar links. I noticed the front swaybar is angled up now using the stock sway bar links. Are extended links recommended or needed?
Old May 15, 2022 | 05:18 PM
  #28
yzf450motoxrider
@Antonm What did you do with the sway bar links when you did the lift?
Old May 16, 2022 | 08:53 AM
  #29
Antonm's Avatar
Antonm
I put a set of adjustable extended sway bar end links on. Mostly to get the end links away from the leaf spring a bit. I adjusted the links so the sway bar was parallel to the ground like it was before the lift.
I think it way these links I used (don't really remember for sure, but I think these are links I used)
https://www.summitracing.com/parts/h...250-super-duty
Old May 16, 2022 | 09:50 AM
  #30
Dweber85rc's Avatar
Dweber85rc
I flipped my stock mount around and mounted it under the frame, this allowed the stock sway bar links I bought not too long before to work. I also added a flat plate on the outside to add support to the frame.
