Sponsored by: Real Truck
Door ajar light on
Old Feb 13, 2022 | 11:36 PM
Agitator44007's Avatar
Agitator44007
Door ajar light on
Hello everyone I just bought a 2002 f350 7.3 diesel. Has 165,000 and the door ajar light is on and so is interior lights as well as rear upper outside light. I’ve sprayed we in door closures and open and closed them-no go. Do I need to take the door panels off to look at switch? Which one or all? I walk away and lights stay in with keys in my hand. Is there a defective module somewhere? Thanks jon
Old Feb 14, 2022 | 08:06 AM
nydiver's Avatar
nydiver
Door switch is stuck in one of the doors. I get it you sprayed the door latch but your going to have to LACE it with pb blaster, kroil, free all, some good penetrating oil and work them open and closed quite a few times. Don't just spritz it, you need to kind of soak it I think towards the top, spray it up into the internals, not just on the face. You may need to slam the doors to jar the switch loose. Once loose, spray it again each day for 3 or 4 days. Then fluid film it to try and get a slick layer that stays. Spray them once a month to keep em trouble free
Old Feb 14, 2022 | 04:25 PM
PROSTOCK's Avatar
PROSTOCK
I had the same problem with our '02 Excursion. It's not hard to take the switch out of the latch, I mean I did it. Once there use your favorite brand of cleaner and spray away actuating as you spray. I was amazed how much crap came out of that little switch. I don't remember how many I did, but I never had to do the same one twice. You can do as nydiver suggests, but that can make a mess and I like to get to the root cause.
metaluno67
Jan 4, 2014 07:36 PM
sbowling79
Nov 7, 2012 09:25 AM
dfoxengr
Oct 8, 2012 02:13 PM
dirgio
Jan 26, 2011 05:19 PM
JG454
1997 - 2003 F150
May 5, 2010 10:37 PM
