Sponsored by: Real Truck
Reset TPS on a 2011 SD?
Old Feb 13, 2022 | 10:54 PM
Clover_SD's Avatar
Clover_SD
I googled the procedures but it says for a 2011 I need some kind of tool to reset the warning message????
Horn will sound once and TPMS telltale will blink once train mode is initiated. If equipped with message center, it will display TRAIN LF TIRE. Place antennae of learn tool on sidewall of LF tire 180 degrees from valve stem to activate sensor. Horn will sound once sensor has been recognized, Repeat step for RF, RR, and LR tires.”
What is a “learn tool” and do I really have to have one to get the message to go away? I’m not sure why it came on in the first place, none of my tires are low. Bad TPS? If so any way to tell which one?
Thanks
Wade
Old Feb 14, 2022 | 07:50 AM
Just Strokin's Avatar
Just Strokin
you can get them off eBay.
search for Ford TPMS tool
here is the Ford OEM version.
https://www.ebay.com/itm/363582694706
There are cheaper OEM ones than this one. Or you can go generic (chineses). I have a chinese one and it works fine.
Old Feb 14, 2022 | 08:01 AM
nydiver's Avatar
nydiver
Or you can get a large holed magnet and slide it over the valve stem of the tire being programmed. The magnets fields disrupt the signal from the tpms. Cheap and simple hack
Old Feb 14, 2022 | 08:11 AM
Clover_SD's Avatar
Clover_SD
Thanks! Not to expensive. Definitely worth having in my tool box. Never getting rid of the truck.😃
the one you posted said it would not work on my truck when I ran the check fit action. It showed this one as the one I need. They look the same to me!!!😱😃
https://www.ebay.com/itm/363366733614
Thank you very much for the info! This has been driving me nuts!!!👍
Wade
Old Feb 14, 2022 | 02:09 PM
Just Strokin
The check fit is not always loaded correctly by the seller. Both were TPMS-19 tools with the same Ford part number on the bags.
FX44AU
Mar 29, 2024 08:02 PM
1dryfly
Feb 27, 2021 10:07 AM
ctfl
Apr 26, 2018 10:03 PM
mebe2k
6.7L Power Stroke Diesel
33
Nov 15, 2015 10:56 AM
spudly98
Feb 17, 2010 11:44 AM
