Sponsored by: Auxito
Plastic tubes/hoses
Old Feb 12, 2022 | 01:27 PM
z 97ford1's Avatar
z 97ford1
Plastic tubes/hoses
Any ideas as to what these three red/green and white plastic hoses are and what they are called and where to buy or replace them?
Old Feb 12, 2022 | 02:21 PM
Jon Freeman's Avatar
Jon Freeman
Old Feb 12, 2022 | 04:00 PM
85e150's Avatar
85e150
Is that a fuel pressure regulator they are connected to? They might be vacuum lines. Can you trace them out? What year and engine do you have? There a lots of illustrations of these systems on line but the exact application is needed or you'll be looking for days.
Old Feb 12, 2022 | 05:38 PM
steve(ill)'s Avatar
steve(ill)
the are vacuum hoses... there should be a drawing on the radiator cover that shows the diagram.. You can use HOSES or small TUBES from auto store to replace.
Old Feb 13, 2022 | 08:30 PM
z 97ford1's Avatar
z 97ford1
Yea they only have 450,000 miles on them so I think I will replace them. I'm assuming I can just PULL them apart?
They feel like a hard plastic and probably will fail once I start pulling.
Old Feb 13, 2022 | 09:25 PM
85e150's Avatar
85e150
If they aren't leaking and aren't brittle I would leave them......
Old Feb 14, 2022 | 08:44 AM
leolipert's Avatar
leolipert
Trailering
That looks very similar to the vacuum solenoid for the front wheel drive that I just replaced on my four wheel drive F150. It's in a different location though. Is your truck 4 wheel drive?
Old Feb 14, 2022 | 07:25 PM
steve(ill)'s Avatar
steve(ill)
those small tubes are HARD PLASTIC... the black end is rubber.. If they are BURNT or cracked then need replaced.. If they are just HARD, they should be OK ( as long as no cracks).
Old Feb 14, 2022 | 09:38 PM
z 97ford1's Avatar
z 97ford1
4x4
They are hard and probably brittle and feel rough at some spots. I have to move them out of the way every time I clean my throttle body and components and cause concern each time. Hate to be in the middle of nowhere and have these kind of parts fail when it SO easy to replace them at my pleasure.
I'll research to see if they are 4x4 vacuum lines.
afonda
May 9, 2020 02:29 AM
F150'94
2015 - 2020 F150
Oct 5, 2016 03:49 PM
Iceman1777
6.7L Power Stroke Diesel
Mar 14, 2016 12:49 AM
Phased3
Large Truck
Oct 25, 2015 07:56 PM
Rick Cargo
Appearance & Dress-Up
Nov 6, 2012 02:03 AM
