Slight engine knock
Old Nov 6, 2003 | 07:58 AM
Barrys67's Avatar
Barrys67
Question Slight engine knock
I am new to this board and this is my first post. I have 67 f100 352ci that has developed a slight engine knock that only occurs while it is warming up. After the engine gets warm the knock goes away and the engine runs pretty smooth. could this possibly be caused by a timing/ignition issue? I am thinking about getting a Pertronix ignition conversion kit.
Thanks,
Barry
Heres a pic of my ongoing project truck:
Old Nov 6, 2003 | 09:31 AM
heep70's Avatar
heep70
Welcome to the site. Nice looking rig.
I had a knock in my old engine while warming up also. It ended up being a bad rod bearing. I ran the engine for years like that. The oil pressure was a bit low, but it ran allright.
Old Nov 6, 2003 | 01:05 PM
Barrys67's Avatar
Barrys67
Thanks Greg. I was kind of hoping that this was more of a tuning issue rather than an internal mechanical issue.
Hopefully I will be able to get a lot more miles out of it before a major rebuild since it does not leak and uses very little oil.
Regards,
Barry
Old Nov 6, 2003 | 02:28 PM
rusty70f100's Avatar
rusty70f100
Some other things it could be:
1. fuel pump arm on eccentric on the cam getting worn and making noise
2. timing like you said, but that shouldn't change that much, and at idle it'd take a LOT of timing to make it knock.
3. Rod side clearance. This is common and mine does it. The fix requires a rebuild and new rods or a new crank; dont worry about it if you find out this is what it is. A dropped pan and a feller gauge will determine this.
4. Hydraulic lifter going out; the solution is a new lifter and running in the new lifter on the cam. Ask if you have questions on this.
5. Wrist pin; this would require a rebuild, dont worry about it if it doesn't do it warm.
6. Piston slap; Worn pistons will rock in the bore and knock when they're cold. This is another strong possibility of what it is, to check if it's this, back off the timing (retard it) at idle. Set it about at TDC, disconnect the vacuum advance. If the noise goes away, you've found your problem. It'll run like crap while you're checking it, though. If this is what it is, dont worry about it, it requires a rebuild and new pistons. If it gets to the point where it does it warm, start thinking rebuild.
Edit: Dont forget to plug up the vacuum advance hose when checking #6! A golf tee with some grease on it works good.
Well thats about all I can think of.
Let us know.
OBTW, Nice looking truck!
f1barry
26
Dec 18, 2010 02:53 PM
DAFBFD58
Delaware Chapter
26
Apr 23, 2008 03:40 PM
Neilster999
Ontario Chapter
May 15, 2007 08:48 PM
bsmi16490
16
Mar 12, 2007 07:51 PM
truckfarmingcanuck
Ontario Chapter
Oct 10, 2006 07:22 AM
