Sponsored by: Auxito
Cruise Control
Old Feb 10, 2022 | 11:30 AM
ttoptom1's Avatar
ttoptom1
Cruise Control
2001 XLT and CC was working fine last time I used it and now doesn't come on when hitting on-off button or when I try to set speed. Checked fuses and all are good. Any ideas what else to start checking? Never had problems or worked on CC before. Thanks, Tom
Old Feb 10, 2022 | 05:33 PM
Jon Freeman's Avatar
Jon Freeman
There's a lot of pieces to that system. Some ideas on what to check can be found in the article here:
https://www.aa1car.com/library/cruis...l_diagnose.htm
Old Feb 10, 2022 | 08:35 PM
projectSHO89's Avatar
projectSHO89
On trucks of this era, ALWAYS start by checking the switch on the master brake cylinder. It has to pass power to the speed control module in order for it to operate and it is a very high failure rate item.
You can also run the speed control self-test and see what it reports.
Rick NoLA's Avatar
Rick NoLA
Make sure you truck has had this recall work done or you risk fire. Brake fluid leaked into the original switch, shorted in a live circuit and caused fires. Did not know about the recall, and very glad mine wasn't in the garage at the time. My cruise had quit working a couple months beforehand.
https://www.nytimes.com/2008/04/13/a.../13RECALL.html
Old Feb 11, 2022 | 03:58 AM
Fordtrucksgood's Avatar
Fordtrucksgood
When I got my truck the cruise did not work and that was the problem. Got it fixed before any leaks or fires, worked fine ever since. Jim.
Old Feb 11, 2022 | 01:10 PM
manicmechanic007's Avatar
manicmechanic007
True story and the recall put a fused harness out there at the master cylinder.
You should see if you have the little added harness and check that fuse
The recall should have been done on that 01 by now right?
Old Feb 11, 2022 | 05:17 PM
projectSHO89
Well, it's been 16 or 17 years since the recall was issued...
Old Feb 11, 2022 | 05:38 PM
RLXXI's Avatar
RLXXI
At least 18 because it came out right before I left the dealer.
Old Feb 11, 2022 | 07:10 PM
projectSHO89
It was issued in November of 2005. Recall # was 05S28.
Old Feb 12, 2022 | 08:21 AM
ttoptom1's Avatar
ttoptom1
Thanks for the replies. I now have a starting point for troubleshooting.
Old Feb 12, 2022 | 07:34 PM
RLXXI's Avatar
RLXXI
I was still at the dealer in 04 and I know for a fact there was a brake pressure switch related recall or maybe TSB, but damned if I can remember the exact parameters, I thought it was the cc issue. I changed a ton of those leaky switches under warranty. Or perhaps it was just a repair procedure due to the failed cc. Getting old sux.....
jeff69z28
May 7, 2019 11:52 AM
mksnipe
Dec 15, 2015 08:22 AM
mrad
Sep 17, 2010 02:59 PM
lshort
Electrical Systems/Wiring
Apr 1, 2002 07:55 PM
