How to determine coolant type?
Old Feb 10, 2022 | 11:14 AM
troverman's Avatar
troverman
Hi guys,
I bought my truck a year ago from the second owner, and he did give me service records. I can see the coolant was changed, but the type was not listed. In the bottle, I can see its pink / red in color. I plan to change the coolant filter this spring, and I'll lose a small amount of coolant from what's in the filter. What should I refill with to match?
Thanks in advance
Old Feb 10, 2022 | 11:39 AM
seville009's Avatar
seville009
My suggestion would be to download the owners manual to see what coolant is called for (plus it's good to have it around).
since you're not sure what the prior owner put in there, if it were me, I'd do a full drain and flush with the new proper coolant.
Old Feb 10, 2022 | 12:02 PM
bismic's Avatar
bismic
Yeah - don't go by the owners manual. The Ford Gold coolant is a marginal coolant, AT BEST.
You almost certainly have an Extended Life coolant. I doubt that you would have an issue with any of the major brands of EC-1 rated ELC coolant.
If you are concerned about it, then do a series of distilled water flushes followed by a short drive cycle (enough to get good coolant circulation and full engine heat). Then fill with what you want.
Old Feb 10, 2022 | 12:49 PM
troverman's Avatar
troverman
Thanks Mark. I have the original owner's manual, have read it, and read elsewhere the OEM coolant isn't that great. I'll pick up a gallon of EC1 ELC coolant.
TooManyToys.'s Avatar
TooManyToys.
It's going to take more than 1 gallon.
Old Feb 10, 2022 | 12:50 PM
troverman's Avatar
troverman
Was just planning on a top-off...
Old Feb 10, 2022 | 01:17 PM
TooManyToys.
I don't mix coolants, so if I needed to "top off", it would be distilled water. Unless you DO know what's in there.
Old Feb 10, 2022 | 02:20 PM
FiveOJester's Avatar
FiveOJester
You'll lose very little with doing a coolant filter with the typical heater hose -> degas bottle piping arrangement. Some kits include shutoff valves at the filter so you lose even less. I would just top off with distilled water. It's a 7-gal cooling system so you're not going to reduce the concentration much.
Do you know the age of the coolant? I believe the recommended interval is 3yrs on the ELC and with the potential for issues with a 6.0 I wouldn't push it beyond that. Probably best to just drain, flush with distilled and top off with new so you know what's in there and can mix accordingly down the road.
I went with Shella ELC as it was in stock at the local Napa and had the lowest price. It's a lighter shade of red than the Zerex & CAT stuff, almost orangish (still very different than Dexcool however).
Also, I like checking the coolant concentration with a refractrometer. Not expensive and very useful to checking your concentration.
Amazon Amazon
Old Feb 10, 2022 | 02:27 PM
troverman's Avatar
troverman
Looking at the records, I believe it does say ELC but its hand-written mechanic scrawl so who knows.
Problem with changing it...how do you dispose of old coolant? Nobody around here I know of takes coolant, and there will be a lot of it.
Old Feb 10, 2022 | 02:45 PM
bismic's Avatar
bismic
Send it down the drain (but not to a septic system), it is biodegradable. I have a clean-out cap (most people do) on the sewer line. Best place for it IMO. I don't particularly like pouring it into the toilet.
Old Feb 10, 2022 | 02:54 PM
Motohead911's Avatar
Motohead911
QUOTE
Problem with changing it...how do you dispose of old coolant? Nobody around here I know of takes coolant, and there will be a lot of it.[/QUOTE]
Check with your city or county, sometimes they do hazardous waste pick ups and it tends to be free.
troverman's Avatar
troverman
That seems like a massive no-no in my town. I know some of the crew at the wastewater treatment plant, and that facility only treats bacteria and removes solids before discharging into a river. They have a hazardous waste collection day once a year, and antifreeze is on the list. I just don't want to store a ton of it; maybe time it around that point.
Old Feb 10, 2022 | 03:18 PM
LCR's Avatar
LCR
Just top it off with water for now, you’re not losing enough in the filter to throw off any balance.
and how’d you end up in the 6.0 forum, didn’t you buy a brand new truck at one point
Old Feb 10, 2022 | 04:09 PM
bismic's Avatar
bismic
You have biological sludge (human waste) that is only treated for bacteria?? I can't imagine that that is correct. All state outfalls have COD, BOD and possibly TOD discharge limits. Those can not be reduced enough with only filtration and whatever sterilization process they may have (chlorine,, etc). I am very familiar with waste treatment processes. Small amounts of ethylene glycol can easily be treated by waste treatment processes. Almost all waste treatment plants discharge into rivers ........... or is recycled for watering purposes (golf courses, etc).
Oils (which float) are a separate issue.
The BIG no-no is to discharge it to a storm sewer. Rainwater run-off receives little to no treatment before discharge.
Old Feb 10, 2022 | 06:08 PM
troverman's Avatar
troverman
Mark - interesting. I’ll ask my buddy about a “hypothetical” situation and see what he thinks.
