Brakes
Old Feb 9, 2022 | 09:38 PM
hobbie1's Avatar
hobbie1
Brakes
Just started to hear a rubbing sound up front when applying the brakes on my 2018.
I'm at 53K miles and I do tow and Airstream from time to time.
Time for new brakes? If so, go with the factory or is there a good upgrade given that I'm doing more towing....
Old Feb 9, 2022 | 11:57 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Daily driver, lots of stop and go driving?
53K is short miles for the brakes unless you do a lot of town driving, or you ride the brake pedal.
But, just because there is noise coming from the brakes, doesn't necessarily mean the brakes need replaced.
The thing to do is pull the wheels and check the pad thickness.
OEM pads are good, made to last depending on usage and driving style, but they do dust pretty heavily.
Also, you should be using the exhaust brake as much as possible, it will make your service brakes last a lot longer.
I fully expect at least 300K out of my original brakes, but I run almost 100% highway miles, about 1/2 towing heavy, and I use the exhaust brake all the time.
My original brakes on my 2015 RAM 2500 Cummins lasted over 500K, but of course, its exhaust brake was much stronger than the one in the PowerStroke.
Old Feb 10, 2022 | 12:26 AM
hobbie1's Avatar
hobbie1
I had a RAM 2500 before the F250. No towing so never had any brake issues.
With the F250 I do a lot of town driving since COVID. Also made several trips towing all over the North and South West. 7 to 8K in the last year.
Lots of mountain driving with the trailer. May need to boost the trailer brake setting a bit. I'm at 4 now.
I do use the exhaust brake - but probably should use it more.
The rubbing sound when applying the brakes just started today - the front ones.
Getting ready for some desert trips starting next month.
Going to get them inspected on Friday at the Ford dealer in town.
Old Feb 10, 2022 | 05:12 AM
senix's Avatar
senix
Ford does make OEM heavy duty pads. the ones that generally come on the truck are not the heavy duty pads.
Run the trailer brakes a little higher on the gain and use the tow/haul and exhaust brake while towing.
Old Feb 10, 2022 | 07:27 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Dealer is going to be about the most expensive place to get the brakes replaced, better off with a good independent shop.
Old Feb 10, 2022 | 09:26 AM
redford's Avatar
redford
FTE Leadership Emeritus
Also, turn up the gain on your trailer brakes. It sounds like your front brakes are feeling the pain from taking up the slack.
Old Feb 10, 2022 | 12:18 PM
Nogyro's Avatar
Nogyro
I'm only pulling a 6,500 lb jayco with my F-350 and I run my gain on 7 with the strongest power. My old 2010 F-150 only had the gain setting. The 22 F-350 actually has three settings I believe low medium and high Plus the gain settings. Just play around with it so you can feel the trailer brakes come on just a little bit stronger than your truck. It should feel like it's holding you back just a tad..
Old Feb 10, 2022 | 03:25 PM
hobbie1's Avatar
hobbie1
I thought so also. Made a few calls, the dealer gave me a coupon, $50 off each axle and they are actually less. Shop prices in CA have been climbing.... Dealer will install OEM.... and I get some points.
I'm local in a smaller town and have been buying from them for years.
Old Feb 10, 2022 | 04:54 PM
F250 Bushman's Avatar
F250 Bushman
I tow between 7,500 - 8,000 travel trailer. 2021 F250 7.3L Gas. I run my gain at 8. At 4 the trailer brakes wouldn't be helping at all.
Old Feb 10, 2022 | 05:30 PM
knaffie's Avatar
knaffie
The OEM brakes on my 2015 F350 were shot at 40K. New pads and rotors were necessary. Yes, I towed a lot, but I coast a lot and use the turbo brake a lot, so that was surprising. The Powerstop pads I replaced OEM with were shot at 110K, but the Powerstop rotors were salvageable. No difference in braking power between the two, but a WHOLE LOT LESS brake dust with the Powerstop. My 2006 Duramax with 130,000 miles had the original brakes on it when I sold it. Ford isn't doing something right with their brakes.
Old Feb 17, 2022 | 02:00 AM
hobbie1's Avatar
hobbie1
Got my truck back today - front brakes were shot - metal to metal front. Had Ford do the work, rear brakes were good, 8MM left, I'll be setting my trailer brake to 7 or 8 and make sure I have the diesel brake on.
54K miles.
Got the truck ready for the summer, full service / fluids - full synthetic oil which I supplied, front and rear axles, tranny, brake job and cabin filter plus top off including DEF. I $1650 total - given the prices around California that was actually a pretty good deal. Fuel and air were changed at 40K so they were good.
Independent guys are all booked up and wanted more $$$$$
Old Mar 13, 2022 | 02:36 PM
lecatlin's Avatar
lecatlin
4wd Low
Wow, have I learned a lot here. 86k on my 2017 6.7L DRW - and a local shop told me I'm almost metal/metal. I'm looking to see if I can do the brakes myself, or need to have a shop do them. The shop (Les Schwab) says they replace the axle seals as well. Anyway, regarding the exhaust brake, is there much difference between the general setting and auto setting, at least in what way I should run?
Thanks!
Ex'ed out
May 21, 2008 07:52 PM
