ccv reroute
Old Mar 12, 2022 | 04:00 PM
jimzpsd's Avatar
jimzpsd
ccv reroute
Looking for opinions, is doing the reroute worth it or is it as useless as a cai?
Old Mar 12, 2022 | 06:36 PM
2017-350's Avatar
2017-350
I just did mine on my deleted 2020 last week. I think i may have a little less back pressure. The main reason i changed it was BC i noticed oil on my boots when i changed my hot/cold side pipes
Old Mar 13, 2022 | 12:33 AM
honda250xtitan's Avatar
honda250xtitan
this is why i want to do it. my cold side pipe was completely coated.
Old Mar 13, 2022 | 09:20 AM
deveroutdoors's Avatar
deveroutdoors
Is it worth it or is it worth it to you? I don't know. I go back and forth on this one because my is operating just fine. I do have some oil residue on the cold side pipe. But it's not spewing all over the engine bay and it's not really a problem if functioning as designed. I have no problem doing mods like +0HP deletes but where I start to hesitate is by changing things drastically from the OEM engineering. The engineers did a good job; the finance people and .Gov are what is holding them back.
The general consensus is the Misimoto kit is probably the best overall. If/when I get around to doing this, this will be the kit I go with. I have a few other priority items in front of it.
https://sinisterdiesel.com/i-2408936...kaAmCvEALw_wcB
Old Mar 13, 2022 | 11:15 AM
jimzpsd's Avatar
jimzpsd
[QUOTE=deveroutdoors;20325447]Is it worth it or is it worth it to you? I don't know. I go back and forth on this one because my is operating just fine. I do have some oil residue on the cold side pipe. But it's not spewing all over the engine bay and it's not really a problem if functioning as designed.
I think its more of a matter of how much oil residue the inter-cooler can hold before it becomes an issue, thats my concern............if its showing up in the tubing then it has to be puddling in the bottom of the cooler restricting air flow. It won't show up in the engine bay (its supposed to be an air tight system). I'm sure folks here have done this and I want to hear from them too.
Old Mar 13, 2022 | 02:12 PM
deveroutdoors
[QUOTE=jimzpsd;20325582]
Yeah, no doubt. I think this mod has its place but it's one of those more gray areas. It's a bit more difficult to see a direct gain. Like I said, when I get through some other priority items I'll likely do this one. I see direct value in the catch can.
Old Mar 13, 2022 | 03:03 PM
jollyrogr's Avatar
jollyrogr
The factory CCV box is supposed to act like a catch can, but it obviously doesn't catch everything. One option is to just run a hose down underneath the truck, potentially with a can on the end of it to prevent dripping. The downside to that is the crankcase only vents when pressure is > atmospheric. The factory setup keeps the crankcase at less than atmospheric pressure. Less air, less resistance for rotating assembly.
F0rdc0wb0y
78
Jan 27, 2020 10:06 AM
lovemy150's
Mar 24, 2011 10:17 AM
busdriver47
May 6, 2006 05:19 PM
