Ford transmission
Old Feb 8, 2022 | 05:24 PM
Leebone's Avatar
Leebone
Ford transmission
I put a T series transmission in the place of the E series transmission , I changed the wiring harness but only one out of two plugs would connect nutrial safety switch works and I hooked up the TV cable as required for the T series, it goes in reverse and drive but will not **** from 2nd to drive can someone please give me some insight into what I need to do
Old Feb 8, 2022 | 05:33 PM
Conanski's Avatar
Conanski
What flexpkate did you use? The one from the E4OD or did you buy a new one specifically made for an AOD?
Old Feb 8, 2022 | 05:43 PM
SFaulken's Avatar
SFaulken
There's no such thing as a "T-Series" or "E-Series" transmission.
Regardless, your TV cable adjustment is wrong, if you put an AOD in place of an E4OD, and it won't shift right (or the transmission is no good) I think Conanski is also correct, that if you just bolted the AOD up to the engine without changing to the proper flexplate, you've likely got the torque converter either pushed too far into the pump drive, or not far enough.
Old Feb 8, 2022 | 05:54 PM
timbersteel's Avatar
timbersteel
As was mentioned, did you use the correct flexplate? If you used the E4OD flexplate and then bolted the AOD transmission to the block, the AOD is most likely trashed now.
Old Feb 9, 2022 | 02:52 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The vehicle in your profile is a ‘92 F-150. Is this the vehicle you are working on and what vehicle did the transmission(s) come from?
Old Feb 12, 2022 | 10:58 AM
Bentlee's Avatar
Bentlee
Yes it's a 09/91 and the truck it came out of is a 3/92 both have 5.0 motors
Old Feb 12, 2022 | 11:02 AM
Bentlee's Avatar
Bentlee
It's both come from 5.0 engine s
And they bolted right up to the tc ?
Old Feb 12, 2022 | 11:03 AM
SFaulken's Avatar
SFaulken
They probably will. The bolt/Stud pattern is probably identical. The *depth* of the flexplate, in relation to the crankshaft flange, however, is most likely not.
Old Feb 12, 2022 | 11:07 AM
Bentlee's Avatar
Bentlee
Does that mean I need to change the flywheel and would the speed meeter not working couse it not to shift ?
Old Feb 12, 2022 | 11:09 AM
SFaulken's Avatar
SFaulken
An automatic transmission doesn't use a flywheel, it uses a flexplate. And yes, I suspect you need to get the proper AOD compatible flexplate. If this is a fully mechanical AOD transmission, the speedometer has nothing to do with it. The *only* input that the AOD uses to determine when and how to shift, is the TV cable.
Old Feb 12, 2022 | 11:29 AM
timbersteel
I'm getting lost...
Is the OP Bentlee or Leebone?
Old Feb 12, 2022 | 11:30 AM
SFaulken's Avatar
SFaulken
Originally Posted by timbersteel
I'm getting lost...
You know, I have no clue, I wasn't even paying attention to the usernames...
Old Feb 12, 2022 | 11:34 AM
timbersteel
Ok. I was just checking. I don't have the memory I used to have, but Leebone hasn't been back since several of us tried to help/answer his thread, but Bentlee has made several posts in the thread.
Old Feb 13, 2022 | 05:07 AM
tjc transport's Avatar
tjc transport
i ain't rite
me thinks leebone made the original post, and for whatever reason opened a new account and now goes by bentlee.
either way, without knowing what transmissions he is playing with, no one can help him.
it appears he has a 91 with a 302 and is trying to put in a trans from a 92 with 302.
Old Feb 13, 2022 | 06:31 AM
My4Fordtrucks
Both users have same profile so….same person?
Yep. Hard to help when not being given all pertinent information.
Zazoos
30
Oct 3, 2018 06:53 PM
BlueOx460
Mar 29, 2017 07:17 PM
unome
Ford Truck Parts for Sale
May 11, 2016 08:02 PM
vintshave
May 31, 2013 11:05 PM
Rollin.IH.Coal
15
Nov 4, 2011 10:28 AM
