Sponsored by: Auxito
Code p455
Old Feb 8, 2022 | 09:53 AM
z 97ford1's Avatar
z 97ford1
Code p455
Recently, I cleaned my throttle body and surrounding components of carbon buildup. Seems now I'm getting this code "evaporative emission control system leak detected (gross leak).
Did a quick look but did not see anything obviously wrong.
Any ideas where to look?
Old Feb 8, 2022 | 10:03 AM
WWR's Avatar
WWR
Did you physically remove tb to clean it? I'd look very carefully at any lines or hoses you disturbed. A smoke machine is perhaps the easiest way to diag this if everything looks ok visually. They can be had on Amazon relatively affordably but it's still a specialty tool the average Joe might not want to invest in
You can try the old brake cleaner/carb cleaner trick but I've almost never had luck with this.
And for giggles....just make sure your gas cap is tight
Old Feb 8, 2022 | 11:08 AM
z 97ford1's Avatar
z 97ford1
Actually, I just had a smog test and they said my gas cap was faulty and threw it away and gave me a new one so I will check the cap.
They have done this before even though my other gas caps would not throw any codes. Maybe there's something about their caps. Seems like in the past I've removed their caps and added a simple AutoZone cap with no problems.
I also wonder why these smog places have on hand a cap that will fit my truck?
Somethings going on here.
I did physically remove the tb and surrounding components and cleaned with carb cleaner.
Been doing this for years as regular maintenance.
Old Feb 8, 2022 | 02:15 PM
projectSHO89's Avatar
projectSHO89
The P0455 may be an "old" code from when the old gas cap was installed. Were the codes reset (or not) when the cap was replaced?
Old Feb 8, 2022 | 04:29 PM
z 97ford1's Avatar
z 97ford1
Usually when I get a "check engine" light I get right on it and see what's going on. The c e l just came on two weeks after the cap change. I just now deleted the cel from the truck and TIGHTEN the cap. If that cap is faulty then the cel should comeback on shortly....we'll see. If the cel reappears then I will go buy another one from AutoZone since they don't throw a code. I'll keep the SMOG cap and put it back on at the next smog event.
z 97ford1
1997 - 2003 F150
Feb 8, 2022 09:49 AM
Buck268
2009 - 2014 F150
Oct 4, 2013 09:51 PM
bodabdan
1983 - 2012 Ranger & B-Series
Jun 18, 2005 06:53 PM
miked79928
Apr 2, 2005 10:03 PM
satkins1044
Sep 5, 2004 11:26 AM
