351M timing chain cover
Old Feb 6, 2022 | 08:48 PM
78Truckster's Avatar
78Truckster
It's been a while since I've had a 351M torn down. I may have a problem with the eccentric for the fuel pump and it's difficult to see the timing chain cover with the A/C pump and hoses in the way.
If I recall correctly, to get to the eccentric I need to remove the water pump and the timing chain cover which is essentially a flat plate. Can I remove the timing chain cover without having to drop the oil pan such as with a 351W?
Old Feb 6, 2022 | 09:13 PM
tbear853's Avatar
tbear853
400 timing cover install; lower oil pan? - Ford Truck Enthusiasts Forums (ford-trucks.com)
Same for a 351M. It can be done with minor mods to the lip on the lowest edge of the timing chain cover.
Stock
, it will not go straight in with the front oil pan gasket "seal" and channel on the cover. ... but it has a seal for the crank shaft, so it needs to go straight in.
What are you thinking is wrong with the eccentric?
chrisjr2287
Feb 12, 2023 09:57 AM
dbickford
Dec 13, 2014 08:21 PM
mike4x4
Jul 21, 2009 10:10 PM
HighRollin
Nov 26, 2004 09:06 PM
