94 F150 MAF Sensor Code 157
Old Feb 7, 2022 | 08:31 AM
Pcompton's Avatar
Pcompton
Ok, I'm gonna give it a shot! Thanks for the help. I'll report back later this afternoon. Thanks again.
Old Feb 7, 2022 | 10:49 AM
Pcompton's Avatar
Pcompton
Ok, Ive tested everything, Im pulling the PCM… I got all screws loose…
how in the hell does this thing come out of the hole?
I’ve googled, many responses say, just pull it out… that can’t be true… this s.o.b won’t pull out.
Old Feb 7, 2022 | 11:06 AM
Pcompton's Avatar
Pcompton
Lastly, now that I'm convinced the PCM is cooked. (Nearly every pin once exposed had some sort of corrosion on it).
Have any recommendations for a reputable place to get a new one online?
Old Feb 7, 2022 | 11:19 AM
rla2005's Avatar
rla2005
It does not just pull out...
I have used a broom stick to pry down on the inner fender a bit to get some clearance.
Old Feb 7, 2022 | 11:30 AM
Pcompton's Avatar
Pcompton
Yeah, I watched that video...and many others. If you notice, they all cut the video until they get it most of the way out...
But what you're saying is...It does pull out (there are no additional clips, screws, etc)....it's just an S.O.B. to get out.
Old Feb 7, 2022 | 11:31 AM
rla2005's Avatar
rla2005
Most folks use NAPA, O'Reilly's or Rock Auto these days. I would use someone local so you can warranty a replacement easier if required.
Old Feb 7, 2022 | 11:32 AM
rla2005's Avatar
rla2005
I have never had much problem removing a PCM. But thes again none of mine had corrosion on the outside or inside.
Old Feb 7, 2022 | 12:46 PM
Pcompton's Avatar
Pcompton
Ok, I'm at my wit's end. Other than taking a plasma cutter to it, I have no idea how to get it out of the hole.
Are we sure there aren't any clips somewhere? There are 2 small clip-looking things on the sides, but nobody ever mentions them.
1. I've run PB Blaster into the hole.
2. I've removed the tire and the entire wheel well.
3. I bought a bolt and threaded it into the PCM to use for leverage...The bolt stripped all the way out, and disconnected...The PCM never budged.
I've been yanking on this thing in one way or another for over 2 hours. It doesn't move.
Old Feb 7, 2022 | 01:12 PM
Pcompton's Avatar
Pcompton
I wonder if I can get at it from inside the truck? Maybe take off the driver's side kick panel and properly beat the living hell out of it with a large hammer until it either shatters into 50 pieces or pops out the other side?
Old Feb 7, 2022 | 02:07 PM
My4Fordtrucks's Avatar
My4Fordtrucks
No advice to give. I have the previous body style. Mine come out from inside the cab.
Old Feb 7, 2022 | 02:58 PM
rla2005's Avatar
rla2005
There is a large cast piece of metal that I have found makes getting at the PCM from inside the cab very difficult. It may give you some leverage to push it forward perhaps.
Old Feb 7, 2022 | 03:42 PM
Pcompton's Avatar
Pcompton
Got it!! Holy mackerel. Thanks for the help guys!
Old Feb 7, 2022 | 04:00 PM
  #28
rla2005's Avatar
rla2005
Glad you got it out. Nice video. Overall the condition inside is not bad from afar, but with all that corrosion on the outside you can bet there is damage inside as well as the pins. Check the cowl drains to make sure they are clear to allow moisture to drain out. Look closely at the seams to see if you have a leak getting into the cab. I think the hood/cowl seal extends over the PCM are too. Something else to look at.
Old Feb 7, 2022 | 04:05 PM
  #29
Pcompton's Avatar
Pcompton
Will do. Thanks again for hanging with me and my struggles today. Ordered the new PCM from RockAuto (My preferred) will be here Wednesday. Hopefully, this will cure what ails me.
Ronqqq
Aug 24, 2021 07:08 PM
fixingbus
1983 - 2012 Ranger & B-Series
Mar 28, 2008 06:05 AM
penman39
Mar 15, 2007 08:55 PM
kanepjk
Bronco II
27
Dec 17, 2006 08:23 AM
huckster
Modular V8 (4.6L, 5.4L)
Sep 12, 2003 11:26 PM
