Bronco II Ford Bronco II
Rear Brake problems....
Old Nov 5, 2003 | 09:47 PM
1988 Bronco II's Avatar
1988 Bronco II
Unhappy Rear Brake problems....
I have replaced the rear wheel cylinders on the drivers side twice in 1 month and the pass. side once in the same time period! It appears that the entire guts of the brake system have just fallen apart when I pull the drums off. I have a manual that shows a sort of clip for the parking brake to pad attachment, however my B2 does not have that type of device? Please HELP, I am becoming way too good at replacing pads and wheel cylinders....
Old Nov 6, 2003 | 01:41 AM
plilikoi's Avatar
plilikoi
Re: Rear Brake problems....
It sounds as though the shoe retaining springs and clips are missing, although I don't see how you could put it together like this.
Why do the cylinders keep failing? Are the pistons over-extending?
Old Nov 6, 2003 | 07:10 PM
1988 Bronco II
Yes the pistons are over extending, and all the springs are in place when the drum goes back on.
Old Nov 6, 2003 | 07:32 PM
Ken00's Avatar
Ken00
Are you adjusting the brakes after you put the drum back on.
Old Nov 6, 2003 | 10:30 PM
1988 Bronco II
I think I found the problem, I was not putting the adjuster back in properly. The adjuster was in turn not adjusting out but was turning in , falling out, and destroying everything in its path around the drum! I certainly hope this fixes it for the last time...
Hawkmcgee
Aug 26, 2014 08:07 PM
mlc8761
Jul 7, 2013 06:01 PM
EMS-guy
Jun 30, 2011 08:20 PM
stangfan78
Nov 8, 2009 01:10 PM
newtattoobob
1983 - 2012 Ranger & B-Series
Sep 10, 2002 02:22 PM
