Drivers side front brake locks
Old Jul 6, 2013 | 04:47 PM
mlc8761's Avatar
mlc8761
My 1993 4.9 SWB F150 front drivers side rotor locks up unless I ease into it, I have changed the rotors,calipers,brake lines,brake pads. I have bled the brakes and proportion valve and it still locks up, also replaced the rear drums, wheel cylinders and brakes in case the computer was reacting to something I did not see. If anyone can shed light or may have an idea on this please let me know.
Old Jul 6, 2013 | 05:25 PM
90'F150's Avatar
90'F150
I'm still learning with these trucks but it sounds like an abs problem to me
Old Jul 7, 2013 | 06:01 PM
zombie_killer's Avatar
zombie_killer
My .02 cents to your front brake issue...is it possible that your passenger side caliper is leaking pressure, giving you the impression that your driver side is locking up?
Otherwise, check to see if you have an ABS sensors on each wheel. And check each sensor that you find. See if they are your culprit.
93f250tn
1983 - 2012 Ranger & B-Series
Dec 6, 2011 04:30 PM
stephendudra
Feb 4, 2011 08:12 AM
17fordguy
Oct 23, 2009 12:01 PM
fiford
Aug 21, 2007 11:39 AM
jrisebo
May 4, 2005 04:30 PM
