DRL back to bright
Old Feb 2, 2022 | 05:37 PM
mattymax's Avatar
mattymax
DRL back to bright
2019
Anyway to check if the dealer dimmed my day time running lights ?
i told them not to when I had it in for a few things and it still shows in my app.
if they did I wanna turn them back up
Old Feb 2, 2022 | 07:22 PM
4wd6.7L's Avatar
4wd6.7L
The actual DRL lights, in the day time, are not dimmed, it's when you turn the headlights on that the outer LED's will be dimmer. It might be hard to tell, but with a helper, or maybe parked facing a window or another vehicle that enables you to see the reflection, switch from DRL(auto,daytime,drive), to headlights and see if the outer LED brightness stays the same.
If you told them not to, and it still shows in the app as an open recall, then they didn't change it.
Old Feb 2, 2022 | 07:25 PM
powerboatr's Avatar
powerboatr
was there a recall on the drls???
Old Feb 2, 2022 | 07:30 PM
4wd6.7L's Avatar
4wd6.7L
Yes, only on the pre-2020 trucks (18-19). I let them do it on my 19. The headlights are plenty bright even with the reduced brightness of the outer LED's.
Old Feb 2, 2022 | 07:54 PM
cat-alac's Avatar
cat-alac
2019 had awesome lights between the non dimmed drl and actual headlights, way brighter than my 22 leds.
bluefishgary
Dec 15, 2019 10:21 AM
johnboy74
Oct 10, 2018 08:17 PM
oldglory
Dec 2, 2013 01:24 PM
fordatlast
1997 - 2003 F150
Apr 25, 2002 02:42 AM
j.frank
Nov 5, 1999 08:18 PM
