Lowering Excursion - What parts do I need?
Old Feb 2, 2022 | 11:53 AM
ADower's Avatar
ADower
4wd Low
I inherited a 4x4 6.0 excursion which has a 6" lift on it. I am moving toward lowering it back down to stock or near stock height.
I am planning to do the following. V springs in the front and modded B in the rear with Rancho 9000 shocks and moving to 33" tires instead of 37".
Other than new U bolts in the rear, can someone please help me with any additional parts that I would need in the front? From my research looking through other posts it looks like I would need a new track arm bar, pitman arm, and factory sway bar end link. However, I am not 100% sure of this and am not very mechanical. Any help is greatly appreciated!
Old Feb 2, 2022 | 04:21 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Sounds like you have the jist of it, without seeing pics of exactly what you have its hard to add anything to your list.
what is your desired finished ride height as measured from center of hub to fender lip ?
Old Feb 2, 2022 | 05:31 PM
WE3ZS's Avatar
WE3ZS
Aaron, post those pictures up that you sent to me along with your hub to wheel well arch measurements.
It looks like he currently has aftermarket front springs and stock rears with a added block.
Old Feb 3, 2022 | 05:32 AM
SmackDaddy's Avatar
SmackDaddy
You don’t need to change the pitman arm or track bar.
Old Feb 3, 2022 | 11:27 AM
pirate4x4_camo
technically true but if he is lowering it to achieve better handling than he would certainly want to use the shorter stock ones.
not to mention longer steering box life
Old Feb 3, 2022 | 11:40 AM
SmackDaddy's Avatar
SmackDaddy
I was assuming he had a stock pitman, lots of guys do 6” lifts and neglect to use a drop pitman. I’m at 4 1/2” and my adjustable track bar and drag link are parallel.
Old Feb 3, 2022 | 12:02 PM
ADower's Avatar
ADower
4wd Low
I'll post up a few pictures here today. Having issues moving them over from my phone to my computer for some reason.
Old Feb 11, 2022 | 11:34 AM
timf150's Avatar
timf150
I had an excursion with an 8" lift. It was an all springs lift. From an old thread here is a list of parts I gathered.
Here is a link to that thread https://www.ford-trucks.com/forums/1...l#post11802543 This was done over 10 years ago so some things may have changed slightly.
Not listed here is the stock front drive shaft, I purchased.
__________________________________________________ ________________________________________
I am finishing up on a similar modification. I purchased an X with an 8' inch superlift kit on it.
Here are the original parts I had to obtain first.
Stock pitman arm
Stock track bar bracket.
Stock sway bar end links
Stock shock brackets.
Stock rear leaf springs to Mod the B's
Stock rear block.
Things purchased new for the v/b setup.
New shocks
New front V code springs
New Rear B code springs
All new u-bolts and nuts
Rear sway bar -Hellwig
Like I said I just finshed this up so everything is fresh in my mind. I will PM you my number if you would like to talk more about it.
The worst part about this change for me was the fact that I had to lift the truck so high to get the old springs off.
Here are the parts that were removed.
Old Mar 1, 2022 | 06:51 PM
05dsg250's Avatar
05dsg250
Trailering
I’m very much interested in doing this same thing to my X I just bought. I bought it to take the family on vacation along with the dogs. Just took the dogs for their first ride and lifting a 120lb Great Dane into the back seat sucks with 6” lift and 35s. I think I’d be much happier with a closer to factory height with 33s. What kind of hub to fender measurement will the V/modBs give you? This will clear 33s with no problem?
Prior to this first trip with the dogs I was thinking ProComp 4” springs and keeping 35s, I’m over that already though if I can fairly easily get a little lower.
Old Mar 1, 2022 | 06:52 PM
ADower's Avatar
ADower
4wd Low
My excursion actually got totaled out. Someone tried to steal it when we were in vacation in Mexico. Feel free to keep the thread going 05DSG250, if you need to.
Old Mar 1, 2022 | 06:56 PM
05dsg250's Avatar
05dsg250
Trailering
Oh WOW, that’s a quick way to ruin a vacation. Hopefully you’ll be able to find another X if that’s the route you want to take.
Old Mar 1, 2022 | 07:44 PM
SmackDaddy's Avatar
SmackDaddy
I still have the Ford V and Mod B springs if anyone is interested. Thieves ruined our sale!
Syphlyn
Dec 14, 2020 12:28 PM
F5 DEEG
20
Sep 4, 2019 10:39 AM
Patriot_RAM
Jul 1, 2012 08:03 PM
kawkx500
Dec 22, 2010 07:38 PM
gregbenner
Oct 16, 2010 07:54 PM
