no start.
Old Nov 5, 2003 | 08:40 PM
bullwinkle7401's Avatar
bullwinkle7401
no start.
i have a 86 f250 4x4 6.9 4spd new injection pump all glow olugs good and power to them, new controler. good batteries,starter cables could not locate any air leaks. will only start cold with a touch of ether,doesnt matter if plugged in or not. after getting started and running for a second will restart no problem. what am i missing?
Old Nov 5, 2003 | 11:40 PM
Spectramac's Avatar
Spectramac
Are you sure all the plugs are working? How cold are we talking?
Please make sure those plugs AREN'T working before you give it any either. We don't want any blown pre-cups.
Old Nov 6, 2003 | 09:52 AM
bilder12's Avatar
bilder12
Just because it is plugged in doesnt mean it should start. It takes time for the block heater to heat the engine to a start temp. One of the glow plugs will cause a hissy fit in cold weather. Ether will cause the heads to lift off the block if the glow plugs ignite it. If it has to be cranked for some time there is the possibility of fuel leaking back. The fuel does not always show up as a leak on the return lines. Keep us posted.
Powerstoke73
Oct 20, 2014 07:58 PM
RobbyMartin
1997 - 2003 F150
38
Feb 22, 2010 07:15 PM
cmbroo1
Oct 27, 2007 10:49 PM
CSSuperDuty
Nov 16, 2005 08:34 AM
