Rim size
Old Jan 31, 2022 | 09:30 PM
ackland3's Avatar
ackland3
Rim size
I have a 1962 f350 i'm trying to put different rims on since 17.5" tires are so hard to find. I measured the spacing on lugs and came up with 7 and a quarter inch it's an 6 lug but I can't seem to find this pattern anywhere. Am I measuring wrong or is there another explanation?
Old Jan 31, 2022 | 10:50 PM
Christmas's Avatar
Christmas
Obsolete lug pattern is the problem. You could have a set of custom rims made. Sorry.
Old Feb 1, 2022 | 05:14 AM
GJCAT's Avatar
GJCAT
6 lug wheel
I just made a set for mine from a set of 10 lug dually wheels. They have the same bolt diameter and center hole measurement as the 6 lug wheels. I filled all the 6 lug holes and machined the 6 lug pattern into them. It was a lot of work but the result works. It was all done on a Bridgeport mill with a Toke rotary table.
Old Feb 1, 2022 | 07:03 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Not sure why 17.5” tires are hard to find. Coker, Universal, M.E. Miller, and Lucas Tire should sell STAs. Tires might cost more than at Wally World but without the expense of new wheels. Stu
https://www.universaltire.com/truck-...transport.html
Old Feb 1, 2022 | 11:53 AM
ackland3's Avatar
ackland3
https://www.tires-easy.com/215-75-17...recode/TH71409
would something like this work? seems to be fairly close. I don't want to spend 300 a tire for a rusted out old ford is why i'm having troubles.
Old Feb 1, 2022 | 12:08 PM
truckdog62563
Sure, if you are okay with the 16 ply rating. That’s gonna rattle your teeth, but would work. The ad calls it a truck tire but I’d be inclined to see it as a trailer tire. The STA bias ply tire is 8 ply. Stu
Old Feb 1, 2022 | 12:14 PM
ackland3's Avatar
ackland3
it rattles my teeth anyway with the lack of any real suspension lol i don't really drive the truck regularly but I have a fordson model f that i'd get a kick out of towing with it so new tires are a must.
Old Feb 1, 2022 | 12:19 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
If it rattles your teeth, you old coots need to use more PoliGrip or Fixodent. Maybe some Permatex if you’ve got that lying around.
regidog
21
Dec 14, 2016 03:10 PM
Stevebarbour
Apr 17, 2009 07:45 AM
Flat8
Mar 13, 2009 03:05 PM
Skotty
Offroad & 4x4
Mar 2, 2004 06:07 PM
crispy2010
Nov 18, 2003 10:10 PM
