Fuel Pickup
Old Jan 31, 2022 | 05:30 PM
redman84's Avatar
redman84
Fuel Pickup
Hey all,
I’m a bit out of touch with the community and am wondering if there’s a better fix for the recurrent broken fuel pickups than just perpetually replacing them. I need to do mine again and wanted to ask before doing the same thing and hoping for a different result. I did read where someone notched some fuel line and wrapped it with a metal screen which seems very plausible but I’m iffy on actually doing it.
Thanks in advance…
Old Feb 1, 2022 | 07:58 AM
Dmco's Avatar
Dmco
Most guys who ditch the rubber “shower head” filter screens use compression fittings to extend the hard pickup line down to the bottom of the tank. Then they run a replaceable filter somewhere between the tanks and engine to catch any debris.
Old Feb 1, 2022 | 02:26 PM
kmjone00's Avatar
kmjone00
There are some good photos of this approach in post 86 and 118 of user Khan's thread here:
https://www.ford-trucks.com/forums/1...-thread-3.html
And he pointed out to me an option of adding a frame-mounted filter (in lieu of problematic in-tank strainer) mentioned in this link in the Super Duty thread:
https://www.ford-trucks.com/forums/1...l#post19216921
Old Mar 2, 2022 | 12:46 PM
redman84's Avatar
redman84
I’ve got the compression unions and hard line. I have a pre-pump filter but thought about adding the little transparent inline filter before the tank selector as well. Is that needed? And if so, are the hoses between the hard lines and tank side of the selector 5/16” or 3/8”?
Old Mar 2, 2022 | 02:21 PM
AHenry014's Avatar
AHenry014
When i converted to the single 38gal rear tank, i bought a new sender and did not have any portion of the "shower head". I ended up buying a 1 foot length of rubber tubing designed to be submerged in fuel and used it as a "dip tube". I secured one end of it to the senders feed tube and the other end got trimmed with small reliefs so it cant suction itself to any flat surface. When i installed the sender, i made sure it sat at the bottom of the tank. Its been working perfectly fine for about 800 miles so far. Ive gotten the tank down to less than 30% fill without issue.
Look into Gates submersible fuel line if youd like to go that route. This is specifically what i bought:
Amazon Amazon
Old Mar 2, 2022 | 04:28 PM
pern21db's Avatar
pern21db
I just run mine without the strainer. I know I'm not getting every drop of fuel out of the tank but I'm also not risking anything because the pickup is an inch or so from the bottom of the tank. I've been happy with it that way for about a year now (knock on wood).
SandR
6.4L Power Stroke Diesel
Feb 3, 2012 04:28 AM
PSDLOVER
163
Jun 11, 2006 11:13 PM
Tadashi
General Automotive Discussion
May 25, 2004 06:15 PM
cek181
15
Feb 21, 2003 07:28 AM
stover007
16
Dec 26, 2002 10:08 AM
