Exhaust Manifold Stud
Old Jan 28, 2022 | 08:02 PM
Richie Whitworth's Avatar
Richie Whitworth
Trailering
One of the studs on my v10 exhaust manifold is busted. I know this is a super common issue, my question is this an 'avoid driving til its fixed' issue or no? If not, what signs should I be watching/listening for to know its definitely time. Just bought the truck last weekend and knew about the issue just wondering how quickly I need to address it.
Old Jan 28, 2022 | 08:37 PM
Dweber85rc's Avatar
Dweber85rc
Just one, no. Keep driving.
Old Jan 28, 2022 | 09:51 PM
WE3ZS's Avatar
WE3ZS
I agree, it will start to make some noise when it gets bad enough to need addressing. Keep an eye on the rest of them, the failing has started.
Old Jan 29, 2022 | 10:50 AM
pwhiteley2004's Avatar
pwhiteley2004
Stealing/Continuing post: I also have one broken stud, but there is an obvious "rattle"-sound upon startup (it doesn't last long). Is the leak at the one broken stud enough to cause damage, or, as you have already stated, wait til more break?
Old Jan 29, 2022 | 11:36 AM
Dweber85rc's Avatar
Dweber85rc
A broken stud will not cause a rattle. Check your heat shields instead.
Old Jan 29, 2022 | 11:41 AM
pwhiteley2004
Good to know. Thank you, Dweb
Old Jan 30, 2022 | 09:54 AM
wpnaes's Avatar
wpnaes
I’ve had 3 broken for a while, keep on…
Old Nov 23, 2023 | 07:52 AM
Radiantworks's Avatar
Radiantworks
1st Gear
Broken exhaust studs
I recently picked up a 2014 F 550 with the V10 6.8 gas. Noticed a ticking noise so we did a smoke test on the exhaust system and confirmed I had exhaust leaks with three broken studs on driver side, and one broken on passenger side. I’m in the middle of changing the exhaust manifold on the driver side, YouTube is a godsend, nearly impossible to get to the lower studs over the engine mount so I took a saws all and cut the manifold at the flanges, and that worked great. So far I’ve gotten nine out of 10 studs out. Hopefully I’m on the homestretch. You need patience because this is not a one day job and go to Harbor freight and buy a boatload of bits. An easy outs and right angle drills just so you have everything you need, you can always take back what you don’t use.
Old Nov 26, 2023 | 05:22 PM
01__Excursion's Avatar
01__Excursion
I used one of these form the local auto parts store for the V10 I briefly had. Worked great, I did have to heat a few of the studs too.
https://www.farmandfleet.com/product...extractor.html
F100supercrew
Aug 20, 2020 07:31 PM
knuckleharley
WTB - Parts & other
Jan 10, 2017 11:33 PM
zjohnson3
2009 - 2014 F150
Mar 16, 2016 02:01 PM
3Lstroker
1997 - 2003 F150
Nov 14, 2011 09:41 AM
R. L.Jensen
Jul 14, 1999 09:09 AM
