Inherited 2005 Ford Excursion
Old Jan 25, 2022 | 05:05 PM
ADower's Avatar
ADower
4wd Low
Hello,
I've inherited a 2005 ford excursion 6.0. I have been browsing the forum for an hour or so but cannot seem to locate an answer for my question. Please keep in mind, I am not a car/truck guy so some of the stuff I am describing might sound ridiculous. I am not one for having a lifted vehicle and would like to keep this more of a daily driver.
The excursion is lifted with at least a 6" lift (has fox 2.0 shocks) from what I can tell. Doing my research it doesnt seem you can do a 4" lift with 37 " tires(37x12.5x20).
A couple questions:
1/ What is the best way to go back to stock ride height or near it and possibly keep the wheels and get a new set of tires. Since this will be a daily I would like it to ride less harshly.
2/ If I cannot go back to stock height (I am assuming parts are no longer available). What is the next best option? Are there 2" lift kits available? It seems like I can only see 4" lifts or greater.
Old Jan 25, 2022 | 07:01 PM
WE3ZS's Avatar
WE3ZS
Originally Posted by ADower
Hello,
A couple questions:
To determine exactly how much lift it has now you can measure from the center of each hub up to the center of the wheel well arch opening and then compare that to the stock measurements that we have listed here.
Getting the wagon back down to stock or near stock height is doable, what will need to be changed depends on what’s under it currently. Can you snap some pictures of the suspension, front and rear to share here so we can offer some solutions? Try to capture the springs and where they attach to the axles, front and rear.
If you want a smooth ride going to short sidewall tires on 20” wheels isn’t the direction to go, taller sidewalls help to provide a better ride, maybe consider 18” - 16” wheels.
Old Jan 25, 2022 | 07:30 PM
Antonm's Avatar
Antonm
I have all four stock springs I took off my 2005 excursion limited 4x4 with a 6.0.
I threw away the stock rear lift blocks but those are still available from multiple places.
I’ll gladly trade you all four stock springs for those fox shocks ( they’ll be to long for you to use with the excursion at stock height anyway)
Old Jan 26, 2022 | 04:24 AM
ADower's Avatar
ADower
4wd Low
Thank you for your response! I’ll def get some pics put up. If I may ask, can I have your contact info? Perhaps text? It doesn’t look like there is a ton of traffic in here. I can send you my # so I can get back to you in real time.
Old Jan 26, 2022 | 04:26 AM
ADower's Avatar
ADower
4wd Low
if I end up going that route with stock springs I can trade you.
Old Jan 26, 2022 | 08:52 AM
WE3ZS's Avatar
WE3ZS
I think that for an SUV that was only in production for six years and had a fairly low production volume that ended 17 years ago that there is a decent level of traffic here at the best EX forum on the web.
Once you have over 10 (I think that’s the number) posts and have been a member for about two weeks (looks like you are good there) you will gain access to the Private Message function here, then you can contact other members via PM. However, I would suggest that you float all of your questions here in the forum as then everyone can see it and add their expertise and experience, I certainly don’t have all the answers.
Old Jan 26, 2022 | 09:17 AM
ADower's Avatar
ADower
4wd Low
I was more or so asking for your number so I could show you the pictures to ensure they're what you were asking for before I put them on here .
Old Jan 26, 2022 | 09:35 AM
Don Naslund's Avatar
Don Naslund
You don't say if it is 4wheel drive. Mine is and it rides rough. It's something that I have gotten accustomed to. One thing that helped with the big bumps are air bags on the rear.
Old Jan 26, 2022 | 10:08 AM
ADower's Avatar
ADower
4wd Low
Yes, it is a four wheel drive.
Old Jan 26, 2022 | 10:12 AM
EXSwap's Avatar
EXSwap
Having only the experience of stock suspension and the Procomp springs (assuming you've got a 4WD), I can say that the stock suspension rode "softer" than the procomp setup I have. That's more due to the shocks than the springs in my case. On stock suspension, I ran the KYB Monomax shocks that they rode great and lasted a good long time (around 100K miles). Being that KYB doesn't make a shock for the ride height I now have, I went with Bilstein's. They ride more like a truck would. However, they aren't really terrible (not log truck). I've ridden in a new Ram 3500 diesel in the back seat and it about took out my teeth. X isn't like that at all.
As to the 37" on a 4" lift, it can be done. Heck, @pirate4x4_camo runs 40's on his and if I remember correctly, he's at 27" ride height all the way around. Then again, he's done some cutting in key areas to prevent rubbing. I seem to remember some folks around here running 37's with pulling back the fender liner a bit as well.
If it were me, and I didn't mind a 6" lift (getting in and out and all), I'd maybe go after some custom valved shocks in order to soften the ride. That'll keep you from doing a bunch of work, buying new tires, etc.
WE3ZS's Avatar
WE3ZS
Sent you a PM, you should be able to read it, even if you haven’t satisfied the requirements to turn it on on your end yet.
Old Jan 26, 2022 | 10:25 AM
96firephoenix's Avatar
96firephoenix
I can poke around in my garage and see if I still have the stock lift blocks from my previous one... I'm about 99% sure I don't but I also know exactly where they would be if I do still have them
@ADower if you're looking at lift kits for F250/F350, the heights are different. the Excursion sat 2" lower than the F250
Old Jan 26, 2022 | 02:55 PM
ADower's Avatar
ADower
4wd Low
I talked with WE3ZS. I am going to go with V springs in front and some Rancho 9000 shocks. I'm not looking to do a lift, instead, come back down to stock height.
s-strah2
Apr 6, 2015 07:36 PM
05Xdriver
Dec 5, 2012 12:20 PM
keepnthepeace
2004 - 2008 F150
Apr 3, 2006 02:56 PM
ridered29
Sep 4, 2005 12:01 AM
