Got new 4:56 gears installed and putting on larger tires. I need a new speedometer gear but can’t figure out exactly where it is. First, is this it? Second why is there a twisted up wire holding it in place?
And if it is not it, what is this?.
This is an unmolested VSS. The driven gear attaches on the input side. The output shows the speedometer cable clip and a better view of the connector for the computer/Speed Control.
