Engine/ transmission combo
Old Jan 25, 2022 | 11:16 AM
BuckeyeDetective's Avatar
BuckeyeDetective
Just my luck. I have been thinking and re-thinking my engine/transmission options and decided to stay with the 239 y-block (for now, at least while I'm rebuilding the motor from a CV) mounted to a TKX T5. I even bought the CV. Then, I found a Coyote 5.0 already paired with a T-45, only 10 miles from my home.
UGH! I know I am early in my project, but I'm tired of overthinking.
Old Jan 25, 2022 | 06:45 PM
spurredon's Avatar
spurredon
Sounds like you need another truck or two to put them all in!
Old Jan 25, 2022 | 07:33 PM
JohnNewb's Avatar
JohnNewb
What a dilemma. Too many engines, not enough trucks.
Old Jan 26, 2022 | 10:34 AM
BuckeyeDetective
Hahaha...
I have only purchased the CV. About a month ago, I had found a Coyote crate motor for less than $2500. I decided against it because it was only the short block. A good friend thought I would have more money in completing the engine, when compared with what I wanted to spend. He also mentioned the amount of decisions needed to complete the motor, I suggested I opt for a running motor.
I wish I had the space for a third truck. My son is wanting to fix up my 1993 F250, which has a 460. Before he said he wanted to fix up the truck, I had considered using the 460 in 1958. The motor was running when I parked the 1993; parked because of brake line issues and gasoline nearing $4 per gallon.
silver_f150
3.8 & 4.2L V6
Sep 30, 2022 12:47 AM
sign_man
Mississippi Chapter
Sep 12, 2008 10:31 AM
This Alamo
Jul 12, 2007 03:08 PM
onefordan
13
Apr 10, 2006 04:55 AM
