Cab & chassis
Old Jan 23, 2022 | 04:34 AM
O'Connell's Avatar
O'Connell
Cab & chassis
I have an 82 f350 I picked up a few years ago. It is set up as a dump truck. Title lists the truck as a cab and chassis. But, from what I'm seeing the frame looks like a regular f350 pickup truck frame. What should I look for to be sure before I pull the dump body off to be sure a pickup bed will bolt right on?
Old Jan 23, 2022 | 01:32 PM
Franklin2's Avatar
Franklin2
If your frame is 34 inches wide, it's a cab and chassis frame. The pickup frame will be wider. Someone could have put the cab with the cab and chassis numbers onto a regular pickup frame. The cab and chassis frame is only narrow in the back, at the cab area forward they are the same as pickup frames.
P.S. Those springs in the picture above do look like regular pickup springs. The cab and chassis trucks I have messed with have 2.5 inch wide springs and it's a tall stack with many leaves in it.
Old Jan 23, 2022 | 01:50 PM
O'Connell's Avatar
O'Connell
It's around 37.5 outside edge to outside edge. 35 from center to center on holes that look like they're for bed bolts.
Old Jan 23, 2022 | 05:47 PM
85e150's Avatar
85e150
The model number on the warranty plate will indicate PU or C&C
Old Dec 22, 2024 | 02:46 PM
bigboi47's Avatar
bigboi47
1st Gear
Rear fuel tank
I have a 86 f350 flat bed and am trying to put a rear fuel tank on but the 38gal one that’s supposed to fit won’t. Any information if the cab chassis are different for that?
This is the skid plate that’s supposed to hold the fuel tank. That is the 38gal and it’s too big
Old Dec 22, 2024 | 03:35 PM
Franklin2's Avatar
Franklin2
The cab and chassis trucks did have a different fuel tank. Good luck finding one.
Old Dec 22, 2024 | 06:30 PM
BigBlue2's Avatar
BigBlue2
https://www.ford-trucks.com/forums/1...l#post21438583
Prionus
Jun 27, 2021 11:13 PM
metalworxartisan
13
Aug 2, 2020 03:44 PM
Coltin1992
40
Dec 10, 2017 09:46 PM
brian1080
Ford Truck Parts for Sale
Jun 26, 2013 11:22 AM
masterbeavis
30
Nov 17, 2008 04:58 PM
