Fuel back pressure
Last year I bought a 1992 Ford F-250 7.3 idi with a banks after market turbo with 240k. I’ve diligently been replacing hoses and filters to freshen things up. Recently I broke down after a fuel line on the back injector passenger side blew off. I believe this is the line that goes behind the motor to the tank? Anyhow, I replaced the entire fuel lines and caps but then noticed pressure building in the gas tanks that also have white smoke coming from them. It also sounds like the fuel is bubbling when the caps off. It’s definitely pressurized. Based on this and a few forums I read I replaced the injectors today. You can imagine my excitement believing I had fixed the air intrusion issue (blown injectors) only to find a massive fuel leak occurring on the passenger side motor area. Probably the lift. Also, fuel now is collecting in the valley in the middle of the engine near the IP and hard lines. I’m beyond frustrated and lost. Any thoughts?
Cheer,
Wheeler
Cheer,
Wheeler
The tanks have to vent, when adding fuel, and as the fuel is being used.
If you think the Lift Pump is bad or leaking, crawl under the engine and take
a look. There is a short hose that is sort of a curly Q from the steel supply line
to the Pump. It could be old and leaking where it is clamped down. Had
that problem a few years ago. Replaced hose and all good.
Couple weeks ago I had an air intrusion problem that was off and on again.
It was the Lift Pump, it was wet on the bottom, replaced it and all is good.
You really should not have a pressure issue with the return system.
Charlie
Anyhow, again the IP doesn’t seem to have an obvious leak points or anything loose that I can tell. I’m guessing once I get the new selector valve installed I’ll start it up and see if I can see where it’s leaking on or near the IP housing.
- 30 micron prefilter
- Holley Black pump
- Wiring Harness and relay for pump
- Dual filter head with filters
- Fuel regulator and PSI gauge
- Fuel return T
- Block off plate with gasket
- 3/8 rubber hose
- Barbed fittings for all items.
You also need:
- #4 hose clamps (optional according to them)
- 3/8 to 5/16 hose barbed adapters
- Bolts & nuts
This is a complete kit and filtration system with Holley Black fuel pump and filters. You bypass the stock filter and can remove it and go straight to the IP. Clamp 5/16 to selector then adapter barbs, then the kit in order.
If you wanted to piece it together and run a electric pump:
20-25' 5/16 hosePump of choice
#4 hose clamps
Block off plateZip ties.
Wire and relayBarb fitting for filter housing NPT
Remove fuel lines from fuel selector to filter housing. Remove mechanical fuel pump and install block off plate. Install the barb fitting for the filter housing and connect the new hose line from it to the selector. Zip tie the fuel line to where you want it so it doesn't sag. Cut fuel line where fuel pump is desired. Bolt fuel pump in and connect hose. Ground the pump, then run a wire to the engine bay to a relay. Connect another wire to the battery with an inline fuse around 10-20 amps depending on pump. Most pull under 10. Then ground a wire from relay and connect the activation power to a switch in cab, IP solenoid, or Glow plug relay with the red/green wire.
I need to make a thread of my fuel system as a guide...
