Sponsored by: Real Truck
5.4L 3v replacement
Old Jan 22, 2022 | 08:19 AM
Just Tryin's Avatar
Just Tryin
5.4L 3v replacement
Hello everyone. I'm new to the page and finally need some help. I have a 2008 F250 5.4L 3V 4X4 auto with 272k on the counter. I really like this truck. It has a clean frame and drive train which is huge in Central NY where the salt is applied to the roads faster than they can mine it! I have taken care of a lot of the steering and suspension over the past year. I mount an 8' service body on it. I put a 9'2" Boss v-blade on the front. I did all of the maintenance. I replaced the manifolds a week ago. Now, I've had ignition issues off and on for a year. Got that all ironed out. Less than 2 miles after doing the manifolds, I dropped #5. Got home, 5 miles, and had dropped #7. Compression test says FUKT! Borescope confirms. What model years van I interchange? Can I use a 5.4 from a 150? I know that the wiring for the coils and injectors is different for some but I'm not concerned about that. I thought I read somewhere that a late production 04-10, maybe, F150 5.4 would work? Expedition? Anyway, what model years and models will interchange for me? And what about a V10 swap? I know where there is a 2008 complete truck available with a busted frame for a 1k. Would it be worth it? I'd have all the computers and wiring from the donor. Let me know, and thank you for your time!
Old Sep 27, 2022 | 06:44 AM
L11's Avatar
L11
So I swapped a 6.2 boss motor for the 5.4 and if I found the 6.8 your looking at I would have paid 5k just to avoid the mountain of bs I went through. I would go with the v10, I believe it’s a straight forward swap. Avoid all but the latest 5.4s if that’s the route your going. My friend has a 2010 with 70k miles and that 5.4 is making worrying sounds already. So just be wary and do your homework.
Old May 9, 2023 | 01:16 PM
Joe Skeens's Avatar
Joe Skeens
1st Gear
I have a 2994 f150 with **** 5.4 3v will a 2014 5.4 3v interchange
Old May 10, 2023 | 06:19 AM
L11's Avatar
L11
yes the engine will interchange with one redesign. Ford changed the head design in 2008 because of the spark plug issue. Which is good new no more 2 piece spark plug iirc. When you are doing the swap be mindful of your sensors I am 99% sure they are the same, it doesn’t hurt to check first. Don’t toss anything until it’s good and running and let us know how you make out 🫡
JustinLB
Mar 20, 2024 11:52 PM
Just Tryin
Jan 20, 2022 10:14 PM
PFD350
Engine Swaps
Apr 26, 2011 04:37 PM
66 BADBOY
Sep 12, 2008 01:16 PM
somf
1997 - 2003 F150
Mar 9, 2005 12:51 AM
