In 2002 I wired such a bypass under the hood of our 2001 Mercury GM using a HD 30 amp all brass "boat switch", a few feet of 12 gauge wire, and 30 amp fuse from battery + terminal to blower bypassing the in car switch, resistor, etc as it was summer, we were on the road, we had a puppy with us. Like said, run the blower on high until we got home and I could get it to the dealer for warranty repair. I used a boat switch as I just zip tied that switch under the right front fender. No more issues, car has not yet tripped 100K, looks new still.
Not long ago, I used the same wire, switch, fuse to temporary operate blower for heat in our '95 T-bird, but just used it once to get to a hospital appt over the mountain. This time, I laid the switch in the glove box. The T-bird is a good running, comfortable car, only has 116K miles, but it needs some paint on it's hood, roof, & trunk. It's also taken some minor hits from others in the parking garage at UVA so I try to only take it over there.
Like with the Mercury, we just used the windows to modulate in car temperatures when switched on.
With the T-bird, it needed an electronic pulse wave control module, it's fixed now. I think with the Mercury was a bad resister board though. My '77 has a resister-controlled blower speed too.
Once the blower starts getting old and harder to turn, they tend to start melting connectors and switches. Overheat terminals. A simple connection to battery is a stop gap measure. But I understand the need sometimes.
When mine started to die, it stopped working in the winter or cold weather, but the next summer I bumped the switch and it came on. Then, the next winter it was dead again. I confirmed the bad motor by straight-wiring it in the cold. I guess the parts of the motor all contracted enough in the cold, that the brushes were no longer making contact with the armature or whatever.
