better traction
Old Nov 13, 2003 | 12:26 PM
Busa01's Avatar
Busa01
Ok, sorry dude. Your right.
Old Nov 14, 2003 | 06:50 PM
fordman300's Avatar
fordman300
so where do you get your auburn stuff and what type of fluid do they use
Old Nov 17, 2003 | 04:44 PM
horizonhuskies's Avatar
horizonhuskies
Tomlongo user doesnt exist anymore...he is busa01. He said he got it from Steeda.
Garrett
Old Nov 17, 2003 | 07:37 PM
Texan1983's Avatar
Texan1983
if you are using this for the street, i would recomend a limited slip. alburn i have heard was pretty good with limited slips. i would recomend a locker for any one who drags his car, or to someone who off-roads. if you are driving around town alot you will get annoied of the clunks a locker gives.
Old Nov 18, 2003 | 03:12 PM
horizonhuskies
Ahh....Mine will be a daily driver...but I do plan on going to the track to see how well I can perform. I was thinking of going with the Auburn pro series LSD. Kind of the happy medium.
Any input on that Texan?
Garrett
Old Nov 18, 2003 | 03:30 PM
Texan1983's Avatar
Texan1983
i'd say that would work fine for you, it will lay down two patches of rubber while you would never notice it was there other wise. i think you will like it. good luck.
Old Nov 18, 2003 | 03:46 PM
borin&strokin's Avatar
borin&strokin
EATON, EATON, EATON, EATON. Auburn is a "light to medium duty" according to THEM. The cone type auburn setup (unless the "pro" is something different from them) won't last as long as the disc type or Eaton type. When I was putting new posi in the vette, not one single shop would warranty the unit (they assembled, and set it up the 4.55 gears for me) assembly. They said when it broke, I would have to go direct to auburn and get parts only from auburn, then have it redone. With the EATON they gave me 12 mo. on the install. Good luck, and SERIOUSLY look at EATON for LSD.
Old Nov 18, 2003 | 04:16 PM
horizonhuskies
Eaton...No one has mentioned Eaton to me.....Is the f150 considered a heavy duty truck? I will check into eaton...just need more info and to do some homework I guess.
Thanks guys! I appreciate your help.
Garrett
Old Nov 18, 2003 | 05:45 PM
FordPerf300's Avatar
FordPerf300
Not to take all credit but, i DID mentioned eaton in my post.
Old Nov 18, 2003 | 05:47 PM
horizonhuskies
Whoops...I completely forgot Ford. I am kinda absent minded some times. Forgive me! Hehe. Any how....I think it would come down to price vs situational need. I think they both make a quality product, you just need whats best for you. I am still leaning towards the Auburn, until I can find info on the Eaton.
Garrett
Old Nov 19, 2003 | 12:12 PM
FordPerf300
Both are very good units, tho the eaton will last much longer and are much easier to beef up. They can be run with i think like 8 clutch discs and 800lb springs, ALOT of force to get the discs to slip.
Old Nov 19, 2003 | 05:04 PM
horizonhuskies
Oh wow.....I hear that....Thanks for the info...tryin to find a local Eaton Dealer.
Garrett
chewedtoothpick
Mar 20, 2013 09:19 AM
maevans
Sep 17, 2009 08:42 PM
Forddeiselman
Dec 29, 2005 07:32 PM
1966ford
Dec 19, 2000 08:19 PM
