Sponsored by: Real Truck
Tie rod issue
Old Jan 21, 2022 | 06:46 AM
Norman Williams's Avatar
Norman Williams
Trailering
Tie rod issue
I just put new ball joints on my 2000 f 250 4x4 when i put it back together i noticed after torqeing the i believe inner tie rod the long one with a slight curve to factory specs the cotter pin is about 2 and a half threads below the grooves on the nut. There was no play or slop in it when i had it off or even now. Is this normal or should i replace it to be safe ? Thanks for any comments
Old Jan 21, 2022 | 08:57 AM
redford's Avatar
redford
FTE Leadership Emeritus
Duplicate thread removed.
Welcome to FTE, Norman. Good luck with your repairs.
Old Jan 21, 2022 | 10:25 AM
nydiver's Avatar
nydiver
Every insertion and removal of a tie rod can wear the mating cup, or a "loose" tie rod will certainly egg it out as it micro shift back and forth. 2 1/2 threads exposed isn't too bad yet. Set it to factory torque, put in a good cotter pin, and let er rip.
bigcrunch
Apr 11, 2016 10:54 AM
mtnxtreme800
Aug 14, 2012 07:00 PM
Impacttec1
1997 - 2003 F150
Nov 15, 2006 06:32 AM
jmegs
1997 - 2003 F150
Jul 5, 2004 08:05 AM
