1970 highboy disc brake conversion
Old Jan 17, 2022 | 09:40 PM
Scottsach's Avatar
Scottsach
4wd Low
so some dumb questions
-i've got the '76 front axle with disc brakes coming thanks to awesome people on this forum! thanks a ton
now i'm a bit lost as i understand from some threads that i need additional items and not sure how/where/what to procure:
-disc brake proportioning valve-should be getting the '76 version so will that work?
-different master cylinder needed for the discs-not sure what to get to address that issue
-vacuum booster-guessing the booster for sale for standard drums for 1970 won't work so what to get and where?
-will i need something to adjust pedal linkage after new booster and/or master cylinder?
maybe there's a thread on all this but haven't found it
thanks all for any insight. excited to get started!
Old Jan 18, 2022 | 07:16 AM
Colorado Ford Guy's Avatar
Colorado Ford Guy
I installed a 76 disc brake axle under my 70 ranger xlt. I didn't change anything else. Brakes worked great! try it out before you start changing things.
Old Jan 18, 2022 | 06:56 PM
fe390pc's Avatar
fe390pc
What he said.
Old Jan 19, 2022 | 06:37 PM
JEFFFAFA's Avatar
JEFFFAFA
What about in a panic stop?
Eric Hamilton
Jan 3, 2020 03:03 PM
johnson.jeff.a
Aug 6, 2014 03:24 PM
pd1808
Jun 9, 2014 07:23 PM
SeaBeeCm1
Jun 11, 2011 08:23 PM
dan_l
Oct 5, 2004 11:23 PM
