4R75W P0750 help
Old Jan 14, 2022 | 01:48 PM
stephen.osborne1's Avatar
stephen.osborne1
4R75W P0750 help
My daughter's '04 f150 SCAB 4x4 gave her a P0750 code about a week ago. I cleaned the contacts on the trans position sensor and deleted the code. Ran and shifted fine until today. She came home for lunch and the truck started rolling backward after she put it into park. The shifter is in the park position, and I really couldn't get the truck to move when I rocked it, but I could see her wet tire marks on the driveway where it had rolled about 4-5 feet. Now the truck won't start. Will a faulty sensor cause this? Bad linkage? I haven't yet crawled underneath to see if the linkage is shifting when the shifter is moved. Thanks.
Old Jan 14, 2022 | 01:49 PM
stephen.osborne1
Also, truck has about 204,xxx miles, about 20,000 on the motor. Trans fluid and filter changed when the motor was rebuilt.
Old Jan 15, 2022 | 06:06 AM
JWA's Avatar
JWA
This problem might be related to the shift tube mechanism and detent located inside the steering column. It could also be an issue with the shift cable running from the steering column to the transmission.
The DTC does refer to Shift Solenoid A Malfunction---I'm not overly familiar with how that would cause or create your issue so I might be completely wrong here.
Good luck with sorting this out!
Old Jan 15, 2022 | 10:36 AM
stephen.osborne1
thanks for the reply. I got underneath yesterday with my wife inside. Had her move the shifter and found the cable is toast. Dealer had one in stock and cheaper than Autozone. I'll be replacing it today.
stephen.osborne1
2004 - 2008 F150
Jan 28, 2022 08:45 AM
BuschWacker
Dec 22, 2018 04:32 PM
SkySkiJason
Sep 13, 2013 03:10 PM
dougielx
Aerostar
Sep 22, 2008 03:23 PM
jethro
Sep 23, 2001 05:43 PM
