7.3 Gas
Old Jan 14, 2022 | 10:32 AM
Lamoon78's Avatar
Lamoon78
7.3 Gas
Anybody with a F350 dually with 4.30 gears give me a real world mpg truck by itself and loaded. Yes I know they wont both be great I have a F350 with the 6.2 and its lifetime average is 9.7 and most of that is towing something. Ordering a 7.3 and was curious on real world numbers.
Old Jan 14, 2022 | 10:46 AM
k.pascoe's Avatar
k.pascoe
You'll get about the same. My 2020 get's 10 mpg.
Old Jan 14, 2022 | 10:57 AM
CR250Bronco's Avatar
CR250Bronco
I have a 250 7.3 4x4 CCSB XLT with 4.30 it’s not a DRW but I think it will be close given the gear ratio.
I *roughly* get 10 around town (lots of stop go at every light)
I took it out on the freeway last night with open roads. I set cruise at speed and reset mpg calculator on screen. I did 16 mile runs with one exit and turn around, so a little hit to mpg there.
75 showed 13 mpg
70 showed 14.1 mpg
65 showed 15.3 mpg
*I just got 8.7 mpg hand calculated 60 miles. No towing, 100% in town (lots and lots of red lights), LOTS of idling and warming up. Outside of intentionally trying to push it down more; I believe this number is the bare bottom of MPG for the 7.3/4.30.
Something to think about; the 4.30 only effect MPG in 10th gear. Otherwise the transmission just shifts up to lower RPMs. I do think the 4.30’s provide a mechanical advantage that helps MPG during acceleration and/or pulling, probably not much. It’s like being in a lower gear on your bike; it’s easier to start from a stop than being in a higher gear.
Old Jan 14, 2022 | 11:57 AM
NeverboughtanFseries's Avatar
'22 7.3L cc 4x4 dually 4.30
1000miles in all hilly terrain
12-13 mpg normal
8mpg pulling 11k tractor set up 60mph
11.5mpg towing 3.5k boat at 75mph
Old Jan 14, 2022 | 12:43 PM
Lamoon78's Avatar
Lamoon78
Thanks for the info guys. Actually quite a bit better than my 6.2 but it is tuned though.
Old Jan 14, 2022 | 02:23 PM
Slowthump's Avatar
Slowthump
I *roughly* get 10 around tow (lots of stop go at every light)
75 showed 13 mpg
70 showed 14.1 mpg
65 showed 15.3 mpg
My 2022 cclb 7.3 3.73 gets pretty similar gas mileage. MPG drops pretty hard with increased speed. I've set the cruise at 82 across the Montana plains and got 12.7 empty. I've seen a legit 16 mpg when cruising 60 empty.
Old Jan 14, 2022 | 03:00 PM
borregoman's Avatar
borregoman
I have the 7.3 with the 4.30 rear end and I carry a truck camper 100% of the time, my GVW is right at 14,000lbs. I average 9 to 9.1 on the freeway cruise control at 65. Around town mileage drops to 8.6.
Old Jan 15, 2022 | 06:47 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
have a couple different duallys with 7.3L about 7-8 towing and maybe 11-12 hwy 60-70 mph.. BTW just curious what cab configuration did you order? std cab ? those are cool.
Old Jan 15, 2022 | 07:46 AM
Lamoon78's Avatar
Lamoon78
its a crew cab my 6.2 is a regular cab.
Old Jan 15, 2022 | 08:38 AM
DaveZX's Avatar
DaveZX
Tell me more about your tuning, 5 star,? Performance improvement?
Old Jan 15, 2022 | 09:10 AM
acadianbob's Avatar
acadianbob
14 MPG unloaded everyday driving; lots of cold starts and below zero weather.
9 MPG pulling an 11K fifth wheel
Just last week it warmed up to 35 degrees and I got 16 MPG on a 70 mile highway trip; 65 mph.
Old Jan 15, 2022 | 09:12 AM
RidgwaySD's Avatar
RidgwaySD
Check 5 Star Tunings site, the dyno charts are there. Even the conservative tune picks up almost 40 lb/ft of torque right in the meat of the power band.
Old Jan 15, 2022 | 10:09 AM
Lamoon78's Avatar
Lamoon78
It wakes the truck up for sure. Its mostly tranny tuning but it makes a huge difference. My wife thought it was dumb that didn’t do anything. Well she drives it a lot when Im at work so one day after about a year I loaded the stock tune back on it knowing she was driving it the next day. She comes home from work and ask whats wrong with your truck I ssid nothing she said something is wrong with it thing acts like it don’t have any power or something. Then I told her what I did and after that she is like well I guess tuning does do something.
Old Jan 15, 2022 | 12:20 PM
acadianbob's Avatar
acadianbob
I'm not so sure it's more power that you can actually feel as it is a more aggressive drive by wire response to your throttle input.
It would be interesting to leave all of a tune in place but pull the drive by wire programming changes and then see how it feels.
Old Jan 15, 2022 | 12:30 PM
Lamoon78's Avatar
Lamoon78
All tranny tuning mostly if I remember correctly when I talked to them there is no drive by wire its not a pedal Commander.
