Problems after alternator replacement
Old Jan 9, 2022 | 03:49 PM
Lanny Sutton's Avatar
Lanny Sutton
Truck is an '04 with the 4.0L engine. After replacing the alternator, starter doesn't engage with the key, will engage when relay contacts are shorted. Also blowing the 30 amp PCM relay fuse.
Old Jan 10, 2022 | 12:32 PM
pawpaw's Avatar
pawpaw
58 reads but no replies, so will see if I can get things started. With the PCM relay fuse blown a lot of things don't wake up & function, so you need to trouble shoot why this fuse is blowing???
Was it blowing Before the alternator replacement & if not When now in the start cycle is it blowing???.
Did you have the replacement alternator Bench tested before leaving the store with it??? Its usually a good idea for us to bench test All electricals before leaving the store because new / reman / rebuilt / salvaged, doesn't automatically make em good!!!
If it doesn't blow @ KOEO, before cranking the engine, use, borrow, or come by a ELM scan tool & running FORScan diagnostic freeware on the viewing device of choice, as discussed here & have it scan for trouble codes. Low Cost ELM Scantool - Ford Truck Enthusiasts Forums (ford-trucks.com), as this inexpensive but powerful combo can query All of the vehicle computer / controllers for trouble code clues, including set, pending & Ford enhanced codes, then post All code Numbers as they can help focus a trouble shoot.
Some beginning thoughts for consideration, let us know what you find.
Old Jan 16, 2022 | 09:39 AM
pawpaw's Avatar
pawpaw
Well Lanny, how is your electrical trouble shoot going, 114 curious minds would like to know what you've found???
Old Jan 18, 2022 | 11:48 AM
Lanny Sutton
Had to put a second alternator on it, seems to be doing fine now. Thanks for your help
Old Jan 18, 2022 | 05:09 PM
pawpaw's Avatar
pawpaw
Ok, good feedback & to hear all now seems well after the second replacement alternator installation.
Old Jan 19, 2022 | 08:15 AM
pawpaw's Avatar
pawpaw
Any forum feedback trouble shooting findings info to post, as it could help someone searching for guidance on their like problem???
Motate455
Sep 23, 2020 10:12 PM
Kendra M. Haugh
Jun 30, 2019 10:57 AM
glassman2
70
Feb 23, 2017 03:58 PM
Montync
Feb 11, 2017 06:03 PM
wisconsin
Feb 3, 2008 09:59 PM
