Help!
Old Jan 9, 2022 | 09:18 AM
Donjr1973's Avatar
Donjr1973
Help!
Hi. I put a new starter on my 87 f150 and it wouldn't start. The starter is fine but I can hear the fuel pumps running non stop. So I replaced the pressure regulator and vacuum line. No help any ideas?
Old Jan 9, 2022 | 10:12 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Usually fuel pumps continuous running, is sign PCM has issues, and its suggested that removing the PCM, and open it up and check for the bad capacitors.
Old Jan 9, 2022 | 10:31 AM
Donjr1973's Avatar
Donjr1973
Thanks
Thank you for the info. Is the pcm the same as the engine control module? Is it under the passenger side kick panel?
Old Jan 9, 2022 | 11:11 AM
stephandrusty's Avatar
stephandrusty
Yes, it is behind the drivers side panel.
Old Jan 10, 2022 | 12:10 PM
Donjr1973's Avatar
Donjr1973
Hi. I took out the computer and turned the switch on and neither fuel pump seems to be turning on. If it's just the filter I'll be so mad at myself lol.
Old Jan 10, 2022 | 12:27 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I’m not sure if I understand correctly, you turned the key to RUN with the computer unplugged and the fuel pumps don’t turn on? That is normal.
Old Jan 10, 2022 | 12:34 PM
Donjr1973's Avatar
Donjr1973
ok I didn't see anything burnt in the computer but the pumps both run non stop with the computer in and it's not getting fuel to the plugs. I've replaced the pressure regulator and vacuum hose to it.
Old Jan 10, 2022 | 12:47 PM
stephandrusty
Computer controls pumps. My guess is you need a new computer..
Old Jan 10, 2022 | 12:56 PM
rla2005's Avatar
rla2005
X2....
The number one symptom of a bad computer is the fuel pump(s) turn on and stay on when cycling the key from the Off to Run position. A few of these pesky computers show no obvious sign of being bad physically, it's inside the magic place where the smoke is still inside with no place to go.
Old Jan 10, 2022 | 01:00 PM
Donjr1973's Avatar
Donjr1973
Originally Posted by rla2005
X2....
Thank you all very much for the help
Old Jan 10, 2022 | 02:18 PM
Donjr1973's Avatar
Donjr1973
Maybe one of you can tell me, if the pumps are running why isn't gas getting to the firing chamber? The truck was running great before I replaced the starter and fuel pressure regulator
Old Jan 10, 2022 | 02:37 PM
rla2005's Avatar
rla2005
The computer is not pulsing the injectors. The timer inside the computer is never getting a reset to go beyond turning on the fuel pump relay. No other functions are working.
Old Jan 10, 2022 | 02:49 PM
Donjr1973's Avatar
Donjr1973
I get it thank you
Old Jan 11, 2022 | 07:35 AM
Donjr1973's Avatar
Donjr1973
i noticed a sensor beside the fuel pressure regulator, could that be an issue? What about a fusible link?
Old Jan 11, 2022 | 08:00 AM
rla2005's Avatar
rla2005
No idea what you are talking about but no sensor will cause your continuously running fuel pump with the key in the Run position issue.
If a fuse was open then a circuit is open. An open circuit will not cause your issue.
