Fuel leaking from fitting
Old Jan 8, 2022 | 08:31 PM
FordTrucksChris's Avatar
FordTrucksChris
Put in a rebuilt 2300 Holley carb and fuel is spilling out the fuel fitting. I'm attaching pictures to get an idea if the way it was setup previously (from the old carb) was wrong. Looking for replacement parts or knowledge on what I'm doing wrong.
Old Jan 9, 2022 | 01:18 PM
f5fordgirl's Avatar
f5fordgirl
Is it leaking at the line flare or between the fitting and the carb, between the carb and fitting there should be a gasket.
Old Jan 9, 2022 | 03:05 PM
FordTrucksChris
Looks like it was leaking around the fitting. What gasket piece should there be ?
Old Jan 10, 2022 | 04:55 AM
Crop Duster's Avatar
Crop Duster
Looks like this. Quick Fuel 8-3QFT Fuel Inlet Gasket 9/16" (holley.com)
You might be able to get one at a local parts house. Make sure yours are 9/16 there are some that are 7/8.
Old Jan 12, 2022 | 02:28 PM
FordTrucksChris
It's actually coming from the line flare. I reused the old fuel fitting that was on the old carb to this new carb. I figured I would also try getting a 3/8" piece but it won't thread on (this was originally on the new carb).
Number4
Apr 3, 2019 12:06 PM
FeralPig
Nov 27, 2015 04:28 PM
Faber
23
Oct 9, 2015 04:07 PM
ihateminimumwage
Jul 19, 2013 09:32 AM
nateraz1
19
Jul 1, 2013 05:54 PM
