Sponsored by: Real Truck
1999-2004 Trac-Bar Bracket Question
Old Jan 6, 2022 | 12:12 PM
80ford100's Avatar
80ford100
I removed the lift off of my 2004 F250. I am in need of a factory trac-bar bracket. I am currently at a junkyard and there is a 99 f250 here with a build date of 02/99. The bracket looks similar to what I think the 04 should look like from memory but I wanted to get a second opinion before I wasted my time pulling it. Is this the right bracket or will I need one from 2000 and up?
Old Jan 6, 2022 | 12:40 PM
DesertSmoker's Avatar
DesertSmoker
All the 99-04 F-250 and F-350 run the same bracket on the 4x4 chassis.
Old Jan 6, 2022 | 12:43 PM
80ford100's Avatar
80ford100
Okay I just wanted to be sure before I pulled it. The bolt that holds the bar to the bracket looks smaller than the one that came out of my 04.
Old Jan 6, 2022 | 12:51 PM
DesertSmoker
Good point. if this is a an early 99 then the trackbar bracket has a smaller hole
Old Jan 6, 2022 | 01:00 PM
80ford100's Avatar
80ford100
Could I just drill the hole out by chance? The rest of the bracket looks the same.
Old Jan 6, 2022 | 01:08 PM
DesertSmoker
I would not drill it out.
Old Jan 7, 2022 | 12:15 PM
99.5_Superduty's Avatar
99.5_Superduty
What is the difference in diameter? In other words, how much would it need to be drilled out?
Old Jan 7, 2022 | 02:59 PM
99f350sd's Avatar
99f350sd
Ya the early brackets are whimpy.....
Old Jan 7, 2022 | 03:08 PM
99.5_Superduty
How much is a new bracket from Ford or junkyard?
Old Jan 11, 2022 | 09:56 AM
80ford100's Avatar
80ford100
I messaged a friend of mine who is a parts manager at a Ford dealership. I had him look up the part number for the vin of the truck in the junkyard and also the same part for the vin of my truck. He came back with two different part numbers that were not identical (Yc3z3a093ab 2004, F81z3a093aa 1999). He also informed me that they are both obsolete through Ford and he could not get his hands on any. Later that day I was able to track (pun intended &#128516 another one down at another yard, this one didn’t allow you to pull parts yourself. After taxes out the door cost was about $57. I could not tell a difference in the two brackets other than the hole where the bolt that holds the bar goes is significantly larger on the 04 style bracket. The trac-bar itself however was way wimpier on the 99 model, looked like a toothpick compared to my 04.
Old Jan 11, 2022 | 10:51 AM
99f350sd's Avatar
99f350sd
I changed mine to the larger one years ago.
Scott51
Sep 4, 2018 02:49 PM
stray
Dec 3, 2015 04:47 AM
dfox99
Jul 22, 2011 10:25 AM
