Sponsored by: Real Truck
2006 wheels for a 2002?
Old Jan 5, 2022 | 04:22 PM
Grant Vogel's Avatar
Grant Vogel
I just bought a 2002 f250. My dad has a 2006 f350 an extra set of Harley Davidson edition wheels. Would they fit on my f250 without rubbing or anything?
Old Jan 5, 2022 | 04:37 PM
kehinnc's Avatar
kehinnc
Try this website for wheel comparisons.
Wheel-Size.com :: Reference guide for car wheel and tire dimensions such as size, offset, PCD
Old Jan 5, 2022 | 04:56 PM
WE3ZS's Avatar
WE3ZS
The ‘06 wheels will bolt up but they will sit about 1.75” too far inward from where they should be, which will cause rubbing on the springs up front. In ‘05 the front suspensions changed and the wheel geometry is different between pre and post ‘05. A set of 2” thick hubcentric spacers will move the newer wheels out to where they should be under the older truck.
Old Jan 5, 2022 | 06:17 PM
Grant Vogel
Awesome, thanks.
Old Jan 6, 2022 | 07:28 PM
mikekerr's Avatar
mikekerr
This is exactly what you need to run those 2006 HD rims on your 2002:
8X170 Hub Centric Wheel Spacers For Ford F-250 F-350 Super Duty Excursion Trucks | For OEM Wheel Spa - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Jan 7, 2022 | 10:05 AM
bwguardian's Avatar
bwguardian
You didn't state weather your truck is 2wd or 4wd. However, I just went through this with my wife's 2000 Excursion that is 2wd. I bought several sets of one year only 2004 18" wheels and wound up buying new 2020 275/70/18 factory spare units that had never been bolted up for the Goodyear tires. The steel wheels have the 05 and up offset and I wanted to see if they would fit as the Excursion has a bit of a different situation for the spare tire cavity storage. The tire and wheel does in fact fit without rubbing anything, but as aforementioned it sits a bit inward. I still would not do this for long term use, but for a spare it's okay for me. The 2" spacers are an option as long as you install them as recommended, but I personally don't like the idea especially for a truck that pulls and/or hauls heavy.
Yellowbeard
General Diesel Discussion
May 14, 2018 02:27 PM
electricman98
Sep 29, 2017 07:39 PM
KSims1868
Jun 1, 2009 01:12 PM
az4x4bronc
Dec 27, 2007 08:11 PM
