I have a 2015 F-250, 6.7. I have a leak on the bottom radiator hose. Its the connection where the small hose connects to the larger hose, the connection right at the bend of the plastic 90 in the large hose. Its just a drip. Has anyone else had this problem and is it something I can repair without changing both hoses?
I dont know but if you have to drain to change, might as well change both while you are at it. Otherwise that guy Murphy will come out of hiding and you will have a new leak... . Are you sure its the hose, and not the waterpump, and AF running down the hose, and dripping at the bottom? thats what happened on my 2011 when I still had it.
I checked it and it is definitely coming out of the connection.
