Engine Identification
Old Jan 4, 2022 | 11:02 AM
P51P28's Avatar
P51P28
Hey everyone. Can someone tell what engine this is based on the photo? Thanks
Old Jan 4, 2022 | 12:07 PM
Thunderkiss1965's Avatar
Thunderkiss1965
FE PROBABLY 352
Old Jan 4, 2022 | 12:52 PM
Crop Duster's Avatar
Crop Duster
It's a 1966 390 bored .030 over with a Comp 268H cam, Edelbrock Intake, Pertronix ignition. And #5 cylinder is a little low on compression.
Old Jan 4, 2022 | 02:15 PM
hiball3985's Avatar
hiball3985
It's a FE and beyond that nobody will have a clue but we will have some good guesses..
Old Jan 4, 2022 | 04:43 PM
Thunderkiss1965
Are you a wizard?
Old Jan 4, 2022 | 05:15 PM
P51P28's Avatar
P51P28
The owner claims it was a police interceptor back in the day. I went and took a look at the truck today and it was a decent example. It had it's issues like they all do but all in all, pretty solid, good metal, no serious rust issues.
Old Jan 4, 2022 | 05:48 PM
spurredon's Avatar
spurredon
Looks like a pretty nice truck though not a fan of the radio cut in. It sure could have been a PI engine. It certainly makes a good story. The casting numbers for the manifolds and engine would start with C?A as opposed to C?T if it came out of a car. There definitely seems to have enough fuel going to it. Kind of surprised it doesn't have headers being on old fast engine. Is that shifting lever a little short or is it just the what the pic was taken.
You might find this chart useful if you come up with the block casting numbers: Ford FE Engine Block Casting Numbers - FORDification.com definitely not gospel.
Old Jan 4, 2022 | 06:08 PM
yardbird's Avatar
yardbird
If a police engine, it's probably a 428. A friend of mine had a '66(I think) Ford highway patrol car. The badges on the side read 428. I know it was really geared for speed over takeoff. It could be up to highway speed before shifting out of first.
Old Jan 4, 2022 | 07:50 PM
tripleframe's Avatar
tripleframe
I can just see Number Dummy laughing right now
Old Jan 5, 2022 | 01:45 AM
P51P28's Avatar
P51P28
Thanks a lot for your comments, appreciate it. So, you think the dash was cut to make that radio fit? Hard to tell,
Old Jan 5, 2022 | 04:20 AM
Crop Duster
Owners claim a lot of things on sale day. The 390 PI engines were only around from 63 to 65 and they were all solid lifter engines. Naturally cams and lifters can be changed, pull a valve cover and if it has adjustable rockers, it might have been a cop engine.
The 428 PI engines were around from 66-70 and weren't all that different from the passenger car 428. They were rated at 360 HP, 25 more than the 428 CJ which was a sure enough high-performance engine. And proves that Ford was lying thru their teeth about the actual HP of the 428 CJ.
Both of these engines were Premium fuel engines. Ask the guy what fuel he burns in that thing. Because both of the PI engines would need 93 octane unleaded and even then, they might rattle.
Old Jan 5, 2022 | 06:11 AM
P51P28's Avatar
P51P28
Thanks a lot for the info. While we were looking at the engine, we both agreed its extremely difficult to know if its a PI engine or not. I'm more concerned the condition of the thing, The truck seems to be a pretty nice example although there are some strikes against it for sure. The paint sucks, headliner sucks, no original interior door handles.The worst thing on the truck is that the radiator supports/mounts are cracked. Looked like someone tried to weld the damage at one point and a fender bender, we think, broke the weld.
On a scale from 1-10, I give the truck about a 6.5. I'd like to believe there are better examples out there for the $$$ but I may be fooling myself.
Old Jan 5, 2022 | 09:55 AM
SwampRattFord's Avatar
SwampRattFord
What are they asking for the truck?
Old Jan 5, 2022 | 10:05 AM
P51P28's Avatar
P51P28
$20k. I think around $16k is more like it but I really don't know. The truck has good bones for sure. When I went and looked at it, it was on a lift. Didn't appear to have many rust issues.
Old Jan 5, 2022 | 11:19 AM
66TotalPerf's Avatar
66TotalPerf
What hubcaps does that truck have?
