2021 FORD F350 Steering Click Noise
Old Jan 4, 2022 | 06:57 AM
SuperdutyHogsontheRoad's Avatar
Question 2021 FORD F350 Steering Click Noise
Started to observe a clicking noise when turning steering left/right as the Temps started to dip in the Northern Ohio.
1) Noise is more pronounced when temps are colder as I didn't hear this sound in summer.
2) Ford Dealer greased the steering column and couldn't hear anything.
Well the noise is back and I have another appointment with the dealer to see what is making this clicking noise.
I'm guessing its the clock spring behind the horn button but want the dealer to look into as its under Warranty.
Thoughts after listening to video?? Driving me nuts..
Below is the video showing the clicking sound from this morning that I shared with Service Manager this morning as well.
Old Jan 4, 2022 | 10:46 AM
2021F350's Avatar
2021F350
I too have noise from the steering wheel when the temps drop to -15 C and colder, mine is more like a clunking noise tho...
Old Jan 4, 2022 | 10:52 AM
is the clunking noise noticeably in the cab or outside the cab and in the front somewhere? My noise from the video is noticeable under the horn cover where the air bag is located I'm assuming. Will see what the dealer says the 2nd time I bring it in. I intentially wanted to capture the sound and share it with them so they don't think I'm crazy.
Old Jan 4, 2022 | 01:32 PM
2021F350's Avatar
2021F350
The clunk is definitely coming from the middle of the steering wheel, something is shrinking from the cold and can then move around inside the horn/airbag cover...
Old Jan 4, 2022 | 07:54 PM
Silverbullet22's Avatar
Silverbullet22
2020 F350 same noise coming from steering wheel. Started hearing it when temperatures started to drop. Has been getting worse since temperatures have dropped more. 🥶 Looking forward to see if dealer finds anything. Thanks and Happy New year.
Old Jan 5, 2022 | 04:51 AM
Will provide an update after my service appointment next week.
Old Jan 5, 2022 | 09:58 AM
MAX4utah's Avatar
MAX4utah
I’m glad you are perusing this. My truck does the EXACT same thing. I’ll be following for an update.
Old Jan 6, 2022 | 07:11 AM
Dropped son off at school this morning when it was 18 degrees out and the infamous clicking has returned. Sent same video to Service Manager.
Strangest thing I have encountered.
Old Jan 6, 2022 | 02:56 PM
blamy's Avatar
blamy
Same for me 2020 F250 XLT.
Old Jan 7, 2022 | 05:03 AM
Talked again with Service Manager after he LISTENED to video and we are both leaning toward a defective Clock Spring behind the horn.
Typically a defective Clock Spring shows when the individual buttons on your Steering Wheel start to NOT work but there have been instances the Clock Sprint itself emits strange noises like in my case and many others.
There isn't that many parts behind the steering wheel. Just plastic on plastic and the clock spring.
Told him while i'm in a loaner to keep the truck as long as possible until the problem is diagnosed and fixed.
Will update as I learn more....
Old Jan 7, 2022 | 06:14 AM
BigRedZilla's Avatar
BigRedZilla
Following
My 2020 F250 CCSB does the same in the cold only
Old Jan 7, 2022 | 06:58 AM
F150 Upgrader's Avatar
F150 Upgrader
3rd Gear
Yesterday
Same exact noise here. Temps dropped to under 25F and it sounds like a ping pong ball bouncing under the horn cover. Only when you turn right and only for about 1/4 turn at a time. Today 10F and very noticeable. Calling dealer today.....
https://youtube.com/shorts/BJ-frWHPeKc?feature=share
Old Jan 10, 2022 | 04:55 AM
Any updates on what your dealer advised you about noise?
Old Jan 11, 2022 | 04:42 AM
Gunny19's Avatar
Gunny19
When I had my 2017 I had multiple trips to the dealer for a sound almost like this when cold out. Eventually they replaced the steering position sensor not the clock spring and all was well.
Old Jan 11, 2022 | 09:06 AM
Thanks for the update I will be sure to pass the info along to Service Department when I drop off truck.
