U joint question
Old Jan 3, 2022 | 03:49 PM
BullnoseLover6.9's Avatar
BullnoseLover6.9
Question U joint question
Hello all, I hope your'e well. I couldn't find anything online and I have no owners manual so here I am. I was curious if anyone knows if I can use one U joint for all locations or I need different ones. Was going to go with GMB 2101203 I think I have 5 or 6 total. Truck is a '85 F350 4X4 w/ T19 and 6.9. Thanks!
Old Jan 4, 2022 | 09:23 AM
tecgod13's Avatar
tecgod13
You need to measure the ones you have. While the rear driveline may share the same ones, the front can be different. The ones in the front axle are likely to be different, especially if its a solid axle. Ford did a few weird ones too where the caps were different sized on the same u-joint.
Old Jan 4, 2022 | 11:32 AM
BullnoseLover6.9
I see. Thanks for this info. I have TTB axle but I'll check them all. I also see you have a ZF6 swap, I would like to turbo and ZF5 swap my 6.9.
40dog
Jun 7, 2017 06:47 AM
vidaliaman
May 13, 2016 08:01 AM
SpringerPop
93
Mar 25, 2013 10:40 AM
apollo11d
Apr 30, 2003 06:06 PM
