can someone be so kind to post pics of the numbers of the stock caster adjusters on a 4x4 F350 or F250?
I am trying to determine which adjusters came on my truck. They were removed for a set of adjusters that came with my lift. The passenger side lip broke upon removal, so I tossed both of them.
Now I want to go back to stock adjusters because, I am doing something else with my suspension. The new suspension changes need the stock adjusters
well to just be confused again, I came across this pic of another members truck. he has this shim on the passenger side...🤷🏻♂️😕 i can make out the part number and the .25 on the shim. it is clearly on the passenger side
2008789 R + .25 degree Camber L - .25 degree camber + 0.4 degree Caster
That is for sure interesting. All I can speak for is my particular truck. I purchased it new and it has never been "taken apart" except for tire rotations that I do myself. Let me know if you need anymore info or pictures.
