Oil additives.
Old Jan 1, 2022 | 02:09 PM
drmikeyb's Avatar
drmikeyb
Trailering
Oil additives.
I forgot to ask if anyone uses or recommends any oil additives such as Hot Shot products. 2019 F250 6.6 with 24k on her and will probably be my last truck. I'm 55 she's paid for and I e got baby her. Thank you
Old Jan 1, 2022 | 03:36 PM
KU4OJ's Avatar
KU4OJ
I have never used oil additives since I started driving in the '70's. My only oil related failure was due to using Quaker State in a Chevy. I have put 450,000 miles on Ford gas trucks with no oil additives. None. So you see where I'm going. No additives for me.
At oil change time I will run a dose of SeaFoam or Gumout (same stuff, really) in a quarter tank of gas. Then change the oil. Never had a fuel system problem.
But never anything in oil, coolant, transmission or anywhere else.
I'm 65. Wrote a check for the truck in the sig. Plan on keeping it 20 years. At 85, I'll probably get something smaller. Or a taxi.
Old Jan 1, 2022 | 03:44 PM
nc350's Avatar
nc350
I never used oil additives in any of my vehicles. I just try to use good oil and change it regularly. Fuel additives I will use from time to time though.
Old Jan 1, 2022 | 04:02 PM
C12H24's Avatar
C12H24
Based upon your other thread, you have a 6.7 Power Stroke. The additive guys will be along shortly.
Old Jan 1, 2022 | 04:20 PM
Josh8811's Avatar
Josh8811
Oil additives is like the Doterra for guys. It's 99.9% bs, but there's a huge "feel-good" market. The chances for a major failure being oil related is almost zero. If you have major issue, it will almost certainly be fuel, emissions, or turbo related. Could be all three. Additives won't do much here either.
Old Jan 1, 2022 | 04:28 PM
C12H24's Avatar
C12H24
Originally Posted by Josh8811
...Doterra....
I had to look that up. Never heard of it. Ha,ha! Yeah. doTerra. That's it.
Old Jan 1, 2022 | 04:29 PM
Josh8811's Avatar
Josh8811
It's another silly @ss MLM scheme that's popular here in Utah. Similar to Mary Kay
Old Jan 1, 2022 | 04:32 PM
BillyE's Avatar
BillyE
Don’t put any additives in your oil. If it meets the spec, it’s proven good for your engine.
Old Jan 1, 2022 | 04:51 PM
Doug Savage's Avatar
Doug Savage
From my 2022 user manual:
Old Jan 1, 2022 | 05:03 PM
schlepprock250's Avatar
schlepprock250
I suppose you're referring to a 6.7... If so, just run a good synthetic oil that's approved by FOMOCO, Motorcraft filters and change it at the severe duty intervals. Oh, and tow something and run er hard from time to time.
Old Jan 1, 2022 | 05:38 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Zero need for oil additives.
If you just need to throw money away, I'm not above taking hand-outs...
Old Jan 1, 2022 | 10:36 PM
bobv60's Avatar
bobv60
Becase of the hydraulic unit injectors in the 6.0 powerstroke diesels using engine oil as a hydraulic fluid there were issues that could be benefited with engine oil additives.
Sence the engine oil in the 6.4 and the 6.7 engine oils only job Lubrication and cooling any of the oils on the Ford approved list will work eithout any extras.
Old Jan 2, 2022 | 02:22 PM
redford's Avatar
redford
FTE Leadership Emeritus
Use only approved oils, then worry more about real things like fuel quality.
matt10461
Jul 28, 2006 04:05 PM
lt
1997 - 2003 F150
Jan 2, 2003 01:20 AM
4x4x4x4
Oil & Lubrication
Oct 20, 2002 04:29 AM
Gary E K
Modular V10 (6.8l)
Oct 7, 2002 12:28 PM
