FLUIDS
Old Dec 31, 2021 | 10:10 PM
RTT's Avatar
RTT
FLUIDS
What fluids you suggest for a 3.03 transmission , a open carry differential , & roller bearing manual steering box ???
I see Ford XG-1C GREASE is recommended. for steering box. It may be dealer only & expensive. I am thinking any GLIC ??? # 2 GRADE equivalent will work.
Trans & diff I have no idea currently...........What u guys think ??????????
Have a drink 4 me............Cheers...........
Old Jan 6, 2022 | 10:13 PM
JEFFFAFA's Avatar
JEFFFAFA
That grease is meant for ball joints, u-joints, etc. I can see it used in the steering box but not tranny and read end. I would use 80W/90 of a GOOD well known brand if you don't go Ford Motorcraft. Example would be Valvolene. Different manufactures of grease and oils add different additives to them.
Old Jan 6, 2022 | 11:19 PM
Philthytoo's Avatar
Philthytoo
I used multi purpose chassis grease in my steering gear, and 80W-90 gear oil in the trans (NP435) and rear axle (Dana 70 with limited slip). Added a friction modifier (from Napa) to the diff oil. I've been told by reputable sources that Napa Brand oils are actually Valvoline under different label.
RenoHuskerDu
May 7, 2019 09:14 PM
jsc83
Mar 20, 2019 02:27 PM
dapug
Mar 9, 2015 01:19 PM
es2rider
Dec 31, 2007 12:38 PM
