302 Lifter tick with no apparent cause
That's an impossible situation on stock E7s.
Did you put that cylinder to TDC, make sure the valves were not open/opening?
2-3 turns would have surely stripped the threads or broken the bolt from zero lash.
2-3 turns, assuming 20 threads per inch, means they tightened another .1-.15" or 1/10th to 15/100ths.
2-1/2 turns would be bang on 1/8".
My guess is your not torqueing the rockers correctly, or do not have that cylinders rockers at TDC when your torqueing them.
1966F100SC
15
Dec 15, 2020 10:17 PM
bhenders
Sep 4, 2016 07:12 PM
