Decode
Old Dec 31, 2021 | 08:21 AM
Dennis Bergman's Avatar
Dennis Bergman
Decode
Can someone tell me what year this is. I’m on a quest to get beaded rims for a 65 f350. This is off of a box truck I found.
Old Dec 31, 2021 | 05:14 PM
85e150's Avatar
85e150
C75 = C750, 23,000 lbs GVWR. I think we can stop right there. Nothing in the wheel, brake or axle department will be compatible with an F350. Wheels might be widow makers.
N = 302 4V Lincoln Y-block gas V8.
8 = 1958 (the question you asked....)
U = Louisville Assembly Plant
27429 = Sequential number
111 = 111 inch wheelbase
A = Black
01D = 1st day of 4th month, 4/1/58
H = Clark model 250V OR New Process model 540, 5 speed direct transmission
72 = Two speed rear axle, only info given in the MPC demo I have is ratios: 6.50/9.04
No front axle code
23000 = 23,000 lbs GVWR
172 3600 = 172 certified net HP @ 3600 RPM
No DSO shown
Old Dec 31, 2021 | 05:22 PM
Dennis Bergman
A = Black
No front axle code
No DSO shown
Thanks. I know they made 70s box truck for ups or uhaul that have the beaded rim for the 65 f350 dually lug pattern. I want to get rid of my split ring. I thought maybe I’d get lucky with the one I found there. Some guy posted it for sale with few pictures and less specifications. Thanks again.
Old Dec 31, 2021 | 05:24 PM
85e150's Avatar
85e150
Beware of the WM wheel. Look them up if you are unfamiliar. They may look like a tubeless in front as there is no lock ring.
Old Dec 31, 2021 | 05:30 PM
Dennis Bergman
Sorry I said split ring. mine have the continuous ring. I finally found a tire shop who would mount and balance bc I didn’t want to touch them. Any way you cut it , I don’t want split, continuous or the widow makers. It’s almost impossible to find the beaded wheels for these trucks in the big 6 pattern.
Old Dec 31, 2021 | 07:14 PM
85e150's Avatar
85e150
You have 6 on 8 3/4"?
Can you post a picture of what you have?
Old Dec 31, 2021 | 07:32 PM
Dennis Bergman
They’re 6 x 7.25
Old Dec 31, 2021 | 07:34 PM
Dennis Bergman
Fronts
Old Dec 31, 2021 | 07:36 PM
85e150's Avatar
85e150
There's more info on those here somewhere, it may take me until next year to find it.
Old Jan 7, 2022 | 04:44 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
The wheels now on the truck have the Firestone RHP unbroken ring 16” rims. Optional on F-350s 1956 to 1966 were 17.5” x 5.25” tubeless one piece wheels made by Budd, either numbers 71320 having six hand holes or 79120 having three hand holes. The below set of 71320s is now listed on eBay. These use 8-17.5” tires that are being reproduced by the STA company and are available from Coker, Universal, and other vintage tire retailers. These tires are approximately 32” diameter which is similar to your 7.50-16”s. Below is a link to the eBay set. Stu
https://www.ebay.com/itm/115070524661
Old Jan 7, 2022 | 09:19 PM
tripleframe's Avatar
tripleframe
What you want and what is pratical are sometimes two different things. You already have new radial tires on safe time proven commercial 2 piece rims. Just carry a good spare tire and wheel in case of flat. The unnecessary, IMO, switch to 17.5" wheels and tires will cost you a small fortune, unless you get very lucky locally.
Old Jan 8, 2022 | 07:21 AM
truckdog62563
I’d agree with that. The Firestone RHP was a time proven rim used as a heavy duty option. Even optioned on half ton and 3/4 tons in SRW configurations as their load capacities were superior to riveted disc one piece wheels. Nothing wrong with keeping them in service if you can find a shop willing to work on them. Stu
Sortofa65
Sep 11, 2020 11:38 AM
Thurston Jamie
Dec 14, 2019 08:29 AM
dramirez163
Dec 30, 2013 06:54 PM
harrisford
Jul 11, 2011 09:35 AM
garlindethfury
Jul 29, 2009 01:53 AM
