Suggestions for long term storage?
I didn't see HRTKD's posts before I sent this.
Another item is make sure your tire pressure is at max or a little more.
maybe find a small local airport and see if you can store in it a hangar corner for small fee
If you leave it somewhere that the truck can get reception, you could also use the app to start it maybe once a month and let it run for about 15 minutes at a time... Before parking it, make sure all fluids are full and you have a full tank of fresh fuel with additives like others mentioned. Maybe even drain off a little of your WIF just to make sure you don't see any water. I would even do a regen on the truck right before you park it so that your DPF filter is nowhere close to full. You can even leave the inside fan set to high so when you crank the truck it circulates some air inside the truck. You could even get one of those Damp Rid containers and put it inside the truck to help absorb any moisture that may build up inside. And like mentioned above, make sure your tires are aired up to the max psi. If you are parking the vehicle outside maybe think about putting tire covers over the tires, or even a cover over the truck... (however, I have always been leary of them because over time with lots of wind the cover can actually scratch the vehicle...) Some even recommend to put the vehicle up on blocks so that the weight of the vehicle is not put on the tires and cause flat spots, which could also ruin the tires with enough time. (Then again, if you put it on blocks, it's one less thing thieves need to do to steal your wheels!) Maybe don't set the parking brake either as I have heard that leaving it set for long periods of time can cause the brakes to freeze up and stick.
Assuming you are parked somewhere that you can trust the vehicle, and that the Ford Pass app will consistently work on both, your end, and the trucks end, this may be a feasible way to store your truck. Plus, with the app you will be able to monitor the fuel levels, location and get notified if any warning or anything pop up with your truck, not to mention start and stop the truck. Maybe you could even talk a friend or family member to ride down and check it out once or twice while you are away...
My Explorer ST had a mode that after like 3-4 days of it sitting it went into battery saver mode and part of that was the functions from the app shut off. Wouldnt remote start from the Ford Pass app.
Hhmmm... I'm not sure. But that would sure shoot that option in the foot!
This is just me and my thoughts on it.
Do you have any suggestions on the best way to keep them alive so that I am not buying 2 x batteries when I get back?
I was going to use a solar trickle charger (sitting on the dash) as it will be stored outdoors. For anyone who went this route, did you have to use 2 x solar chargers (1 for each battery) or are they tied together so that charging one will keep both alive?
Thanks for any info!
what does your insurance say about it being parked for a year? will vandalism or theft be covered?
as far as letting it set, my '99 sat for 3 years, put batteries in it and started it and drove it. I am in Arizona so no microbial growth in the fuel.
NOTE: if the batteries aren't disconnected then there will be parasitic loads in addition to self-discharge. If you disconnect the batteries then expect the radio memories to have forgotten everything and the transmission will have forgotten whatever-the-hell it remembers about your right foot.
Previous recommendations to protect your fuel from turning into vegetable soup are right on.
Ive heard resale prices are nuts - where can I go to get an idea of what it would list for? I was considering just unloading it and getting a new one when I got back.
