fixing rust?
Old Nov 4, 2003 | 10:35 PM
beeskerdog's Avatar
beeskerdog
Question fixing rust?
I've got a 72 f250 camper special. Starting to get rust in that horizontal seam that runs the length of the bed -just above the side moulding. Starting to get bad enough that there are now pin holes in the upper portion of the sheet metal. It looks bad. Is there any way to stop this now that it has gotten this far?
Thanks, beesker
Old Nov 4, 2003 | 11:01 PM
Faithful Old Road Dog's Avatar
I recently saw a thread on this subject. Guys were talking about different procts to use, bead blaasting, etc. You'll need to do a search.
Old Nov 5, 2003 | 09:47 AM
Freightrain's Avatar
Freightrain
Welcome to the site beeskerdog.
Any kind of media blasting will remove the rust from the seam. You will need to braze/weld the holes shut then.....either weld the entire seam(like some have) or use seam sealer and paint over it again.
You may want to go to the bodywork forum and ask guys down there what they have done.
Larry
Old Nov 5, 2003 | 08:50 PM
beeskerdog's Avatar
beeskerdog
thanks Larry -I'll check the body shop form. I know it's a pretty common problem.
beesker
Old Nov 6, 2003 | 02:51 AM
willowbilly3's Avatar
willowbilly3
Go find a rust free bed. I had very slight seperation of the factory body putty ad very minimal signs of surface rust. I was repainting my pickup so I wanted to fix it right. I dug out all the putty and sandblasted the seam, cleaned it with bare metal acid prep, used epoxy primer and then reputtied the seam with the proper material. Three years later the whole seam had rust blisters the size of quarters. Granted, the Alaska winters are hard on vehicles but I don't know what else I could have done to make a proper fix.
Old Nov 6, 2003 | 08:47 AM
beeskerdog's Avatar
beeskerdog
that's the kind of stuff I wanted to find out. I was thinking exactly along the lines of what you described. Sounds like it's pretty much "game over" unless your remove the panels, clean em and then weld them back together.
thanks (didn't want to hear it) but thanks, beesker
JustByron
15
Sep 29, 2016 12:36 PM
Familyhauler87
Aug 5, 2015 10:50 PM
bizzelj
Jul 12, 2015 10:48 AM
Tonkatoy77
13
Sep 8, 2014 09:12 PM
Americanmadeford
Appearance & Dress-Up
Feb 27, 2007 12:28 PM
